Nitro and heat
Boreas
Adirondack Coast, NY
What the heat does is it softens the glue between the neck and fretboard and allows the joint to slip just a teensy bit. When the neck cools, the reorientation of the two boards against each other relieves the compression and allows the strings to neck to pull the neck into relief.
I understand that, but it wasn't much heat. Glue and wood will also change shape slightly given stress + time. May need to add more time, but is heat always necessary?
Peegoo
Beast of Bourbon
I've tried it both ways, and I've found that in order to get the wood to take a 'set' without applying heat, the neck has to be over-flexed which can create problems that didn't already exist. I think it's an unnecessary risk.
