NGD - Squier 40th Anniversary Vintage Telecaster
  • Thread starter Linus Pickle
Linus Pickle
Oregon
A little background here - I am a bass player and have been playing, off and on (mostly on) for the last 25 years. I do most of my own setup and tech work, the only thing I don't touch is woodwork. But I've never owned an electric guitar. Until today, anyway.
This is the 40th Anniversary Vintage Telecaster, specs wise it's on par with a Classic Vibe. I saw these when they came out and were around $500, but passed on it at the time.
But then last week I saw that Musician's Friend had a couple versions of this for $299, with an additional 10% off if you had a (free) account with them. $270 was too good a deal to pass up so I pulled the trigger.
The last Squier I owned was a Bronco Bass, in 1998 when I first started playing bass. It was a cheapo piece of junk and I unloaded it pretty quick, upgrading to a Peavey Foundation. I had a sour opinion of Squier instruments for a long time as a result. But I kept seeing reviews of people trying out the higher tier Squiers and being impressed, in some cases even preferring them over Mexican Fenders that cost 3 times as much.
I'm pleased to say this one not only lived up to the reputation but in some ways exceeded them. The neck on this feels satin smooth - not glossy, which is good because I find gloss finish a little sticky - and there are no sharp fret edges on either side. I've also heard that these Squier guitars can be on the heavy side but this one weighed in at a featherweight 6 lbs 6 oz! I had to double check on my bathroom scale to confirm.
Hardware wise, I find this mostly fine. The pots have a little bit of scratch to them but I suspect that will wear off eventually. If not, I can replace them. The tuners seem alright, nothing jumps out as especially terrible or especially wonderful about them but they do what they're supposed to do without being loose or skipping gears.
The screws to adjust the bridge saddles are a bit soft and my screwdriver already started to strip them when I was setting it up. But I've ordered compensated brass saddles anyway, so they don't need to last.
Sound wise, it's hard for me to gauge yet. I ordered a little Fender Mustang LT25 practice amp but that arrives tomorrow, for now all I've got is a Danelectro Honeytone. A lot of folks don't care for the neck pickup on this, but again, I'll wait and see and if I'm not happy, I can replace that myself.
On top of all that this thing just looks great. Dakota Red is a nice bold color, it even shines through in the matte finish. And the black binding is a nice accent. I'm excited to finally give learning this weird little bass with too many strings that are too thin and too close together a proper go.
Blackmore Fan
That's a beautiful guitar! Congratulations!
Flaneur
Scotland
I have an Epiphone, with that matt poly finish. I really like it- but of course, it would polish up pretty well, if I changed my mind.
Nice looking guitar. So long as the neck agrees with you- and the body is a light one- everything else can be switched out, or tweaked to taste......but you know that. :)
Linus Pickle
Oregon
I finished doing my setup on it last night. While the neck relief was perfect right out of the box (for now anyway, it may change once it settles in) the action was sky high and the bridge sales were way too far neckward - I had to back each one off by maybe a quarter of an inch. Intonation isn't perfect but again, I'm holding off until I get the new saddles before I worry too much anyhow.
Getting the pickups balanced took some tweaking, I had to move both of them down too one I lowered the action. I also noticed that the bridge pickup is very microphonic. I'm not in a position to start a mod project right away but after the saddles are done and I'm not quite so busy the pickups will be next. Any thoughts on Fender Tex Mex pickups for the telecaster? They're pretty affordable and I'd like something a little spicy, which these apparently are.
Linus Pickle
Oregon
Congrats. I have one in blonde. Fantastic guitar, but I did swap the pickups and the pots. The stock pots went from 0 to 10 in about a quarter of a turn.
I was on the fence between the red one and the blonde - yours is much closer to the classic look of a Telecaster. And I didn't realize the wood grain was visible through it from the pictures on Musician's Friend! That's a nice touch.
I took the plate off for a peek last night but didn't see any indication of whether they're audio or linear taper - your description makes me think audio taper though. What did you go with for pickups?
naveed211
Iowa
6.6 lb! You lucky duck. I got a Dakota red one too on super sale for $250, but I’m pretty sure mine is around 8 lb or more. It’s definitely not light. Luck of the draw sometimes. Great guitars, in any case. Enjoy!
Linus Pickle
Oregon
I didn't believe it when I saw it, I moved the scale and made sure it wasn't propped up somewhere else. Then I stepped on my bathroom scale with and without it and got almost exactly the same result. It certainly feels light to me, I've just never had a solid body instrument that weighed so little. I think my lightest bass guitar is a scrap over 8 but I haven't measured since I redid the electronics to an all passive system, it might now be under 7.
Zepfan
Horn Lake, MS
I have the tobacco burst 40th with satin clear on it - aged looking maple neck and fretboard.
Some don't like the looks of it and I have to admit that it had to grow on me. Don't usually like maple fretboard, but this one feel nice.
Pickups. I have a set of Fender Yosemite pickups and really had in mind to install in this guitar. But, these sound very good and I find out they're Alnico 5 pickups.
Guess I'll have to grab yet another Squier to place the Yosemite pickups in.
Pointmonger
Austin, Texas
I put SD Vintage 54's in it. I wanted a Tele with some more 50's twang. I will say it may be my favorite Tele neck pup to date. I'm playing on the neck much more than I do any of my other Teles.
Skydog1010
Old Dominion
Nice.
I do have one question. If that is your bathroom scale, are you and those in your household a family of Smurfs?
Kinda small.
Beautiful guitar. Enjoy.
