NFB resistor question, AA764 Vibro Champ
Discussion in 'Shock Brother's DIY Amps' started by zoran, Feb 25, 2020.
  1. zoran
    zoran Tele-Meister
    Toronto, Ontario
  2. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    The 47R forms a voltage divider with the 2700k NFB resistor. Roughly a 60:1 ratio. The output of the voltage divider is the amount of NFB signal applied.
    Double, or half, that 47R you still have a very low value. But look what it does to the ratio of the voltage divider -- big change to the amount of NFB...
    Also, we need that resistor to be a low value, otherwise look what it does to Rk and therefore the bias of that tube.
    zoran, Mr Ridesglide and King Fan like this.
  3. zoran
    zoran Tele-Meister
    Toronto, Ontario
    aaah, a voltage divider. interesting. it makes sense that it's there for a reason. thanks for clearing that up. still wrapping my head around a nfb loop as a concept. it's incredible.
    sds1 likes this.
  4. zoran
    zoran Tele-Meister
    Toronto, Ontario
    so if the value of the NFB resistor (2.7k on the schematic) changes, is it important to change the value of the 47 ohm resistor to keep the 60:1 ratio?
  5. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Yep, to maintain the same amount of NFB you need to keep that ratio.
    zoran and King Fan like this.
  6. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    And OTOH, different amps can have different ratios.
    zoran likes this.
  7. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    The 47R divider allows for a bypass cap & gain stage that wouldn't work without it. If you check Rob's site about adding NFB to a 5e3, part of the deal is that it doesn't work with the bypass cap in place. So, his mod uses a 3-way switch that allows NFB but disconnects the bypass cap for it.
    Using the voltage divider allows the bypass cap to remain in place and function properly and have NFB. I used that setup on my 5e3, and on a current build I'm working on.
    *** - I think this is correct, but don't take my word as gospel. ;)
    zoran likes this.
