Newest mini board
Discussion in 'The Stomp Box' started by bigben55, Nov 12, 2019.
  1. bigben55
    bigben55 Friend of Leo's
    Cincinnati, OH
    I'm at the point where I know what I NEED. I need the following: reverb, tremolo, delay, 2 levels of overdrive, and something "swirly," and a wah. And nothing else. Reverb and tremolo can come from the amp or pedals.At one time I had a 13 pedal board, most of which either got used for one or two tunes, or not at all, so I pared it down to only the essentials. This new mini board is for a Valvetrain Saratoga amp, that I'll mostly be playing a Les Paul thru. I just got the last piece, the Supa Trem Jr. I'm using a One Spot with zero issues, but will still eventually get a Cioks Adam or DC5. My Wilson wah is not pictured. The only thing that might change is the overdrive. My trusty 1998 FD2 sounds great but in about 7 months, my name will be up on the King of Tone waiting list, and I'll be ordering. That FD2 has been my #1 OD for 21 years, so we'll see if the KOT can do what many have failed at....kicking it off the board. 20191112_151325.jpg
  2. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    That's my idea of a mini board. Full sized pedals with all connections on the rear.
    richiek65 likes this.
  3. McGlamRock
    McGlamRock Friend of Leo's
    San Francisco, CA
    Looks good! I'd love to downsize to a mini-board like that.
    If you don't mind sharing, what kind of power supply are you using (and where is it hiding)?
  4. bigben55
    Cincinnati, OH
    Right now, I'm just running a One Spot with a daisy chain cable. It works, and I have no noise issues. But like I said, I'll eventually get another Cioks Adam power supply. I have another mini board with different pedals for a different amp and the Adam mounts perfectly under these boards. That one has a Strymon Flint, so I HAVE to have a power supply. I have found, One Spots get the job done BUT, some venues have creppy power. What's noise free st home may not be a Bob's Country Bunker, so they're still the way to go. But for now, it can wait.
  5. Lef T
    Lef T Tele-Holic
    Ontario Canada
    I've never tried a Fulldrive.
    Can you just use boost or overdrive or does the boost only boost the overdrive?
  6. bigben55
    Cincinnati, OH
    There are many variations of the Fulldrive 2. They are all good, I've 8wned and tried most of them. The one I use is a 1998 pre flat mids, push pull comp cut on the vol knob, and IMO these are the best sounding ones ever. On mine, the boost is not independent. On some newer models, it is. And now they make a single sized no boost version of my particular one. Lots to research.
    Lef T likes this.
  7. bigben55
    Cincinnati, OH
    McGlamRock likes this.
  8. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    I don't have pics, but if that's a "mini board" then mine is a micro-board:
    EHX Soul Food, Boss TR-2 Tremolo, Way Huge Aqua Puss Delay, MXR 6-band EQ. All powered by a Volto so no power connection needed. There is space to add one or two more pedals but it's hard to see much point when I'm just playing either 50s rock or country-rock. At some point I will go MFX and be done with all this silliness anyhow.
