Newbie pedal what order
Discussion in 'Pedal/Effects Owners Clubs' started by teleplayer99, May 13, 2021.
  1. teleplayer99
    teleplayer99 Tele-Meister
    birmingham, al
    EHX tuner has to go first. EHX soul food, hand made booster/sustainer(My brother) with real dirt, EHX reverb, new brand tremolo, and EHX soul preacher. I am done.
    Thanks guys for all your help,
    Anthony
  2. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Put the tremolo last and the reverb second-to-last. Compressor should come second, right after the tuner. Do whatever you want with the rest. Try some different configs and see how they sound to you.
    Good luck.
    NoTeleBob and W.L.Weller like this.
  3. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    Boost/sustain
    Soul Preacher
    Soul Food
    Tuner
    Reverb
    Tremolo
  4. E5RSY
    Georgetown, TX
    p.s. You may get more responses if you have the moderators move this to "The Stomp Box" forum. Just hit "Report" in your post and ask them via the dialog box that pops up.
  5. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    Compressor after reverb is best. You get some nice reverb tail when the notes stop without having it swamp the playing. Actually two compressors are best, one on each end, along with pre & post e.q's.
  6. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    I have trem before delay/reverb. Sounds more natural.
    BUT as you can see from the replies, there really are no rules--just guidelines to start with. Try it a bunch of different ways and the one that sounds best to you is the best way.
    northernguitar likes this.
  7. NoTeleBob
    NoTeleBob Tele-Afflicted
    Southwestern, USA
    I'll start with "whatever you think sounds best".
    But, something I gleaned from Josh at JHS was that a compressor should be first. Otherwise it will do just what it's supposed to: quiet loud sounds and amplify quiet sounds. That means it will effectively amplify any noise picked up along the way in the signal chain. That's what leads to people saying "my compressor is noisy".
    northernguitar and W.L.Weller like this.
  8. tfarny
    tfarny Poster Extraordinaire
    Hudson Valley, NY
    Try the standard way (wah/comp/boost/od/modulation/delay/verb) and then mess around with other stuff. Putting modulation before dirt can be really cool. I have always found comps want to be first though.
  9. Mark the Moose
    Mark the Moose Tele-Afflicted
    Colorado Front Range
    Tuner first, it may have precision issues later in the chain if other pedals are on.
    Then gain. Boosts are nice before or after overdrives, depending on taste...try it both ways. The sustainer is probably a compressor, which may be noisy and quirky after your drive pedals so maybe it needs to go in front.
    Reverb goes before tremolo in an amp, so try that. On the other hand, reverb is about simulating space, so try it the other way. I like trem before reverb, but I don’t use massive amounts of either so the difference is negligible.
    W.L.Weller likes this.
  10. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    Not counting tuner I usually put comp first. Then dirt. Then processing and modulation. And delay and reverb last. But I’d also say try it several ways. Your ears know.
