Newbie 5f1 Build
Discussion in 'Shock Brother's DIY Amps' started by MD57, Apr 3, 2018.
Tags:
  1. MD57
    MD57 TDPRI Member
    Huntley, IL
    New to the forum and to Amp building. I have recapped some old Hi-Fis and 70's receivers but this is new. I have attached a pic of the board for comments/build validation. Kit is from Boothill.
    Thanks
    Mike
  2. corliss1
    corliss1 Poster Extraordinaire Platinum Supporter
    Lansing, MI
    Any way you can get more space between that 470 ohm cathode resistor and the caps on the left and right? Maybe raise it up? That sucker will get hot and you don't want to cook the caps too much.
    flyswatter likes this.
  3. MD57
    MD57 TDPRI Member
    Huntley, IL
    Corliss1,
    Thanks for the post, is this enough space or should I resolder? Everything else look ok so far?
  4. corliss1
    Lansing, MI
    I'm okay with that :D. I'm sure other people will tell you it needs to be a few feet over to one side or something crazy, but that's good.
    Everything else looks fine when compared to the layout, but I'm sure others will jump in as well to take a look!
  5. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    Looks good. Time to install your wire leads.
    There are videos on my site that you may find helpful.
  6. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    Looks alright. My advice would be to practice your soldering and I find it better to install the wires first, wrapping them around the turret, soldering, and then installing the components into the holes in the tops of the turrets.makes any changes or future repairs much easier.
    kleydejong and flyswatter like this.
  7. corliss1
    Lansing, MI
    Yup - resistors around the turret. Caps, especially electrolytic, through the holes.
  8. flyswatter
    flyswatter Friend of Leo's
    +1, components in the holes. That also naturally creates extra distance between the bias resistor and filter cap, by elevating the resistor and shifting it to the right.
  9. MD57
    MD57 TDPRI Member
    Huntley, IL
    How do I tell which one of the connections on the pot is the ground? Also, I think I am almost ready to solder the tube sockets
  10. jimgchord
    victor,ny
    A traditional fender layout would have that black wire from the coupling cap connected to the right lug of the pot
  11. MD57
    MD57 TDPRI Member
    Huntley, IL
    Finished soldering all of the components. tested with a current limiter before putting the tubes in. The rectifier heats up and puts out the correct voltage but the 6v6 heaters are not glowing and i get no sound. The PT is putting out 5v. I find the information on how to number the octal tube sockets very confusing but have gone over it a dozen times. Pic of the socket attached.
    This is what I was going by: Octal sockets:
    Looking at the socket from the lug side, #1 lug is the one to the left of the keyway slot.
    #8 is to the right.
    Any help would be appreciated
  12. hackworth1
    Looks like the socket wiring on the power tube heater circuit at pin 2 and pin 7 is correct.
    More pictures with the amp turned the opposite direction will help. Take a photo of each tube socket which shows the leads coming from the board.
    Offhand, it looks like you do not have your power tube's cathode resistor at pin 8 connected.
    D'tar likes this.
  13. corliss1
    Lansing, MI
    Is the indicator light working properly?
  14. clintj
    clintj Friend of Leo's
    Idaho
    That 8 pin socket doesn't look right. Looking at it from inside the chassis, with the keyway at 12 o'clock, the pins are numbered clockwise starting to the right of the key.
    Edit: connect the shorting contact tab (center) to the ground tab on your speaker jack. That shorting contact is an important safeguard that prevents damage if the amp is powered up with no speaker. Post several more pics too, please. There's already two errors seen, a peer review of the whole amp would be a very good idea. Suggested shots are the whole chassis from an angle, showing the board and sockets etc, and detail shots of each socket and pot, jack, and such.
    I'd attach one of my pics, but something is not playing nice on my end.
  15. clintj
    Idaho
  16. D'tar
    D'tar Friend of Leo's
    WNY
    I dont see cathode connection to the bias resistor on the 6v6... Revisit the wiring on your sockets. Screenshot_2018-05-11-20-00-43.png
  17. D'tar
    WNY
    Its on pin6 not pin 8
  18. jimgchord
    victor,ny
    Out of curiosity, what output transformer are you using?
  19. jimgchord
    victor,ny
    There should be nothing connected to pin 6 on a 6v6 .it doesn't connect to anything in the tube.
  20. D'tar
    WNY
    Yep, its on pin 6 now
    It needs moved to pin 8
