Newb Q: pedal pot repair
Discussion in 'The Stomp Box' started by ndcaster, Jul 21, 2019.
  1. ndcaster
    ndcaster Poster Extraordinaire Silver Supporter
    Indiana
  2. ponce
    ponce Tele-Holic
    Croatia
    Could be similar. There are also different shaft lenghts. Is there a way you can glue the original one with epoxy, or even solder the shaft ring to the casing?
  3. ndcaster
    Indiana
    good ideas
    I hooked it up and tested it. The contact between shaft and pot body affects the feedback function directly. I'm ignorant about electronics and don't know why that would be, but I did it over and over again.
    I wrote to EHX and asked them where I could get a replacement pot. If they don't send one (which would be nice, but I'm not banking on it), I'll try your suggestion of soldering it. One problem is that the solder might introduce a hump somewhere and prevent the pot from meeting the housing nice and flush.
    a drop of epoxy might work, plus a little solder
    hmm
  4. ndcaster
    Indiana
  5. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    That's really nice of them. No reason why they would pay for the pot you broke, but getting you the info is really thoughtful. For a mass producer to be so helpfully responsive is terrific. Good for them!
    Mouth and Obsessed like this.
  6. Obsessed
    Montana
    +1 That is a really nice follow up from a large pedal company. Kudos to EH.
  7. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    That’s exactly what I was going to suggest. That’s was nice of them to point you in the right direction.
  8. ndcaster
    Indiana
    took off today to desolder and solder (among other things) and lo the handiwork
    but somedays you're the windshield, and some days you're the bug:
    switch cable broke off
    lol
    look, I know it's an old pedal, I should upgrade or something, maybe just chuck my whole rig and move to Tahiti with a Kemper
    but now it's PERSONAL
  9. jimilee
    Chattanooga
    Happens to the best pedal builders. Those ribbon cables are a ***** to work with.
  10. ndcaster
    Indiana
    is it typical for these things to be attached to pcb boards at right angles? isn't that just asking for trouble?
    I'd love to find some female connectors
  11. jimilee
    Chattanooga
    Yep, sure is. You may be able to find some connectors at taydaelectronics.com , that’s where I get mine. Shipping is a little slow but reasonable. Small Bear is another good place. Better quality, but higher shipping.
    ndcaster likes this.
  12. ndcaster
    Indiana
    thanks!
