New to Strats, high E string keeps breaking
Discussion in 'Stratocaster Discussion Forum' started by juxtapolice, Nov 7, 2020.
  1. 1 21 gigawatts
    1 21 gigawatts Tele-Afflicted
    Here is a photo of the Custom Shop Number One. You can see the red tubing.
    juxtapolice likes this.
  2. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    Maybe get some saddles that have longer slots, or file out the slots on your existing saddles, especially the high E. The string shouldn't be touching there IMO.
    I had a 64 Strat, every time my buddy would play it he would break my high E string, that was a LONG time ago, I didn't know much of anything about guitars back then.
  3. monkeybanana
    monkeybanana Tele-Holic
    mmhmm
    Awesome tip. Must have been Cesar Diaz? There is a great video on YouTube of him giving tech tips.
    JIMMY JAZZMAN and juxtapolice like this.
  4. JJLC
    JJLC Tele-Holic
    Twin Cities
    EJ uses a different saddle for the small E.
    Rene Martinez used a small 'tube' to cushion the small E at the locations where the string contacts the inertia block & the saddle.
    Buy extra small E strings; I always purchase a couple of 10 packs.
  5. bluesguy62
    bluesguy62 TDPRI Member
    Kuantan, Pahang, Malaysia
    Yes, Rene Martinez did mention that in a couple of interviews I've read.
  6. dannyh
    dannyh Friend of Leo's
    North Texas
    this...I’ve had a couple strats with this issue. Running the string through a piece of wire insulation was a quick fix.
    czech-one-2 likes this.
  7. Chuck berry
    Chuck berry TDPRI Member
    Memrancook nb Canada
    Well here's my 5 cents worth. Those saddles are not made for huge bends you can but only to a certain degree. At that particular time fender made the saddles in this way. The same as the saddles that has only three blocks. My question is did you try the saddles with grooves in them that allows them to move from side to side? If you did and it still does it there must be a problem between the bridge and where the string where the string enters. There must be a small point somewhere you can't see that breaks the string.
  8. Tark1
    Tark1 TDPRI Member
    London UK
    If it is breaking where the string exist the top of the bridge plate, the bridge plate hole has a sharp edge. It needs to be smoothed and rounded. SRVs tech used to do that with a fine abrasive Dremel tool bit and add a length of PTFE sleeving over the string just long enough to stick up past the hole in the bridge plate.
  9. smoothrecluse
    smoothrecluse Tele-Holic Silver Supporter
    Panther City, TX
    Like other above have mentioned, I would take the bridge apart- remove the saddles, and remove the bridge from the tremolo block and look at everything individually to check for burrs or sharp edges.
    Also, because I feel that it hasn’t been mentioned before, Rene Martinez used to slide wire insulation over the SRV’s string where they break over the bridge plate. :twisted:
    Foxguy and AAT65 like this.
  10. Antoon
    Antoon Tele-Afflicted
    Low Lands
    You saddles also seem not level but tilted to the left in the pic. Each saddle should have the same height where both height adjustment screws are. Otherwise the string will move sideways when bending. This would cut the string.
  11. juxtapolice
    juxtapolice Tele-Holic
    Jersey City
    Thank you. Was actually working on it as I saw this notice. Just popped a modern, gotoh style, bridge saddle on the high E for kicks, as it has a lot more clearance. Setting up now and the guitar is feeling really good
  12. Audiowonderland
    Audiowonderland Tele-Meister Silver Supporter
    Usa
    Nothing to do with tension. There is a flaw / burr on the saddle causing that.
  13. juxtapolice
    Jersey City
    Seems like I was able to fix. Was indeed something to do with the saddle/bridge relationship. My guitar looks like it has a gold tooth now but I kind of dig it. Thanks for all the replies and suggestions
    Antoon likes this.
