I got a paisley t-type body a few years ago that I wasn't really happy with. It sat around in a box for a while, before I decided to just sand it down to wood and try to do my own paisley.
I decided that, to complicate matters, I'd make it a paisley tele custom clone:
... with the period correct three-hole neck plate. ChatGPT told me that the top two screw holes on a three-hole plate should match the four-hole spacing:
ChatGPT lied:
I had great success routing the cavity for the micro-tilt plate:
The next step was primer.
Then the paper, purchased from Rothko & Frost:
Some masking, and the first two coats of clear are on:
That's where I'm at, as of this morning. I'm just going to lay on the nitro, three coats per day, until there is no seam between the paper and the body.
Then I'll add the burst. I've made a telecaster-shaped template that leaves about a quarter of an inch exposed on all sides, because I don't trust myself with a freehand attempt.
I've got silver metallic going on first. Then metallic purple, and then Bob Weir pink. I'm using rattlecans, and I hope that this layered approach will give me a hue that I can live with. I intend for the template to be about 1/4" from the body for the silver and pink coats, and they'll sandwich a purple layer that'll be sprayed with the template about 1/2" from the body. I want just a hint of purple making the transition.
I'll post more photos in days to come, especially once the color starts going on. And I'm flying blind here, so if anyone has any helpful suggestions, I'm all ears.
ChatGPT lied:
