New Power Amp Build Matchless Clubman
dunner84
Victoria, bc
Hello all,
I have been planning a new dedicated power amp project for a while now, and I am finally ready to start cutting the chassis. The power amp will be a relatively faithful copy of the Matchless Clubman with a PPIMV to replace the stock MV, and a switchable added gain stage similar to how the Mesa Boogie 50 50 is setup.
I have several preamps that I will be running through it ranging from simple matchless/vox type circuits, Dumbles, Soldano SLO, and many more. Most of my tube preamps are faithful clones right up to the PI input, so having the option of plugging direct to the PI of the power amp is important. The added gain stage will be for everything else. I think the 3PDT On-On switch will get it done.
I made a quick and dirty layout as the build will mostly be P2P with a small turret strip.
I would love some fresh eyes to take a quick look, and make sure there are no glaring errors.
A few things I am most concerned/unsure about:
- The preamp switch for going between the added gain stage and PI input. I am pretty sure I got it right, but you never know.
- The Matchless schematic has some oddball (to me) resistor node values. I will definitely be tweaking those to get the plate voltages correct.
- The EL34 1K screens seem odd to me. The wattage values are quite high. Maybe someone could school me quickly on that.
- The EL34 cathode resistors seem high. Most amps I looked at go with 270s. The schematic didn't state power handling. I assume 5 - 10W is about right.
- Is grounding the input and output of the gain stage ok as I have done it?
In a previous thread I inquired about adding switchable, variable negative feedback with Presence and Depth controls to this circuit to make some of my higher gain preamps more useable, but the Matchless PI runs with different values than most other EL34 amps I looked at, and I couldn't get any traction on the idea without changing the stock PI. I would like to keep it stock. I will maybe come back to this idea once I have the mp built and working.
I attached the quick and dirty layout, and patched together schematic. I appreciate any feedback!
Cheers!
dunner84
Victoria, bc
I had some time to move things along this week. The choke and PT bell covers were a little rough, so I hit them with some steel wool and spray paint.
I just need to decide on a transformer orientation before I mill the chassis. With the PT wires pointing towards the back of the chassis I gain some room inside for my board, but things will be tight where I want to stick the fuse, and on/off switch. With the wires leading into the centre of the chassis I gain room for the switches, but lose some interior space, and the OT leads don't fall right onto the tube sockets like I want them too..
dunner84
Victoria, bc
Slow progress, but I had some time to mark the PT placement, and cut it out today. I am a little frustrated I didn't punch two of the holes quite hard enough, and the step bit slipped. It would have been much cleaner. Oh well, things fit nicely.
Kevin Wolfe
Lakeland FL
That’s pretty cool 😎. I’d be interested in seeing those pre-amp designs too. I played a rack mounted bi-amped bass rig back in the day so I dig the versatility.
Paulg
Tiburon, CA
I used the Clubman power amp in this recent build. I mated it to a preamp in Merlin Belcove’s book (recommended reading!). Im very pleased with it. The power amp really has that swirling tweedish sound. Simple and effective! Good luck
dunner84
Victoria, bc
That looks great! I love the cabinet! Thank you for mentioning the tonal flavour. That is exactly what I am hoping for. It will be quite different from all of my other big bottle amps. Do you happen to have your voltages? I would love to compare when I am finished.
My project didn't move much this week, but I have the next 10 days off, so I am hoping to be able to get it built and functioning before I go. I also have plans for a faceplate, grill, and head cab later this fall when I have more time off.
Paulg
Tiburon, CA
Thanks for the nice comments. I rechecked my log book. The B+ was 380v and final cathode resistors were 680 ohms for 40/42 ma per tube. I would, absolutely, use this output stage design again. It’s way loud enough with excellent tone. Also makes it easy on the end user, just plug in some new EL34’s and go!
Just a side note on the project. I built this in early Covid times ( can you remember that long ago?). I wanted to clear out some parts I had on hand. Hence, the tweed twin chassis and a JCM 800 OT.
dunner84
Victoria, bc
I made some more progress today. Chassis is cut and drilled out, and started roughing things in to see how it will fit. I ended up choosing an eyelet board from a Hammond organ tone box. I like that it mounts upright. I like the extra room, and wire routing will be a bit easier due to the fact I am not rack mounting this anymore, and I want the tubes towards the front, so I can watch them glow through the metal screen.
The different board layout/tube configuration means I need to redo my layout. I will post a revised layout once it is finished. I just need to figure out the best way to rotate the tube sockets. In the meantime, here are some pictures of the progress so far.
Feel free to comment/critique!
Cheers
dunner84
Victoria, bc
The screen resistor wattages listed on the schematic seem quite high. This got me thinking about the OT impedance. The Trainwreck Express also uses a 25W resistor, and those amps use an OT with a 6k primary. I remember reading once that increasing the primary impedance on a pentode increases screen current. I wonder if Matchless does the same? I did some digging, and I couldn't find an explicit answer to this question.
I have a 35W OT with a 6k tap that may be better for this build, OR I can stick with the 4k tranny, and use the selector switch to try 8k to get that high impedance el34 thing.
2L man
Finland
Those screen resistor power values must have lots of safety margin :)
Using a multimeter and measuring AC voltage over screen resistor when playing long loud notes give good estimate for screen peak current calculatipn. Also DC voltage drop can be used. Multimerers are not best here because Screen operstion can be very dynamuc. Using an oscilloscope it is possible to see detailed operation better.
