New Pot Choices...
Discussion in 'Tele-Technical' started by Texicaster, Aug 21, 2019.
  1. Texicaster
    Texicaster Tele-Holic
    Arizona
    ¡Bueno!
    My '58 AVRI pots are scratchy and before they were scratchy kinda loose anyways so I think I'd like to replace them. Attached file is my Tele.
    Volume worse than tone but both loose and may as well replace both. I assume same cap between them?
    I know NOTHING about pots quality and value wise. I'm happy with the tone and I assume I could get exact replacements but what are my choices and what's the best brand and place to buy?
    Thanks,
    TEX
  2. Chiogtr4x
    Chiogtr4x Friend of Leo's
    Manassas Park, VA
    I just buy whatever is around! ;-)
    ( sorry)
    Texicaster likes this.
  3. RodeoTex
    Nueces Strip
    I've had very bad luck with Alphas. Pretty good with CRS, even knockoffs of them.
    Zepfan and Texicaster like this.
  4. Verne Bunsen
    Verne Bunsen Tele-Holic
    Sonoran Desert
    Those look like CTS, which is good stuff. If you like the sound and control you get out of them, get yourself CTS pots in the same value and taper. Taper is designated by the code on the back: a code ending in 1S will be linear and a code ending in 2S will be audio.
  5. Texicaster
    Arizona
    Thanks!
    What's the bets place for parts? I usually go Stewmac for most needs but never bought pots before...
    T
  6. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Antique Electronics is who I buy from.
    Stewmac only sells A-Audio taper pots. Antique Electronics sells both A-Audio taper and B-Linear taper pots.
    CTS brand and Emerson pots or about the only good pots left on the market these days. I used to get Alpha pots all the time, but they have sunk in their quality and reliability recently.
    Verne Bunsen likes this.
  7. Verne Bunsen
    Sonoran Desert
    I also use Antique Electronic Supply for CTS pots: linear and log tapers and long and short bushings available consistently.
    magic smoke likes this.
  8. dan40
    dan40 Tele-Afflicted Silver Supporter
    Richmond Va
    LutherBurger likes this.
  9. moosie
    on the roof
    The AV pots are CTS, and are high quality. Perhaps they just need cleaning. A quick spray of DeOxIt should take care of the scratchiness.
    If you want the same pots, Darren Riley is a good source for the AV hardware, and most everything else Fender.
    That link takes you to the Pure Vintage Fender pot, which is stock in that guitar. Pair of 'em will run you $14.
    Darren's good to deal with.
  10. DougM
    DougM Friend of Leo's
    Honolulu, HI
    Being the old Hippie that I am, when I saw the thread title, I thought it was about Maryjane, or Pakalolo, as it's called in Hawaii, lol.
    frank a likes this.
  11. Matthias
    Matthias Tele-Afflicted
    Can’t go wrong with CTS. Look for dimple-backed if you want the same look, be be aware some of their vintage-style pots have deliberately low torque to replicate a bit of looseness on a well used pot.
    The Fender Pure Vintage will be like-for-like replacements.
    If you haven’t tried this before, be careful not to fry that cap. Try and put a crocodile clip between the lug and the body of the cap (if it’ll fit) to conduct some heat when you desolder/solder. Those caps aren’t cheap!
