So in the body blank case I save $$$ on material but add $$$ in working time. I document both...
Great stuff, thanks for sharing!
Two questions, if you don't mind...
First, about the bowed 1/4" top, do you mean wet the conCAVE side? You want that side to swell, to force it straight, no?
Also, way back when you jointed the center body billet. I'm not clear on how you did it. I would have used the jointer to do one side, and TS for the other, then planer for thicknessing, as per normal. If I read correctly, you didn't use the jointer at all on this piece, but fed it through the planer edgewise... both sides? I see that getting them parallel, but not necessarily straight.
Just trying to learn...
Thanks. And yeah, jointer then planer (not TS), realized that soon as I posted.Yes.. Concave.
The usual way... Jointer first side (there was no photo) and then thickness planer for the other side
