New Design Proto Build - Lyra
Discussion in 'Tele Home Depot' started by preeb, May 16, 2019.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Main usage is for wood drying and treatment but I also use it as described above for the thinned Shellac to get absorbed into the surface
  2. ratter
    ratter Tele-Meister
    PA
    I'm always amazed at the level of thought and detail that you put into every step. It's something we should all aspire to.
    And I love all the softened edges on this design. It reminds me of a river stone...
  3. preeb
    Sonoran Desert
    For the color scheme I want something that will look vintage 40's style and will complement the Mahogany to its deepest most lustrous look.
    I will be using Shellac based color coats and start with what I call "Rusty Cherry". Both builds will receive the same color scheme with the maple top model getting a vintage honey top color.
    Both backs will also get busted.
    Here we go...
    The mahogany top proto sprayed with Rusty Cherry all over
    Followed with a darker shade of the same color to burst the top, back and sides.
    The burst is mild and masks the transition glue lines nicely adding even more depth to this beautiful color
    Note how flat and smooth the finish film is already without the need for sanding sealer. Only two coats of clear and that's it... no sanding and no extra unneeded coats (-;
  4. preeb
    Sonoran Desert
    The Maple build is getting the same color for the back but the top is kept clear
    I now manually and very carefully clean up the over-spray down to the high recurve line keeping the line perfect and smooth
    Overspray removed from the sound holes
    and scraped around the board with this modified razor
    like this
    Amber Shellac sprayed
    first "Dirty" mid coat added
    second darker "Dirty" mid coat added
    and now I get back to the same gun I used for the back bursting to transition the top to the back
  5. preeb
    Sonoran Desert
    The glue line is there but just enough...
  6. preeb
    Sonoran Desert
    I'll let them hang for a day before spraying the clear nitro
    The lighting in the spray booth is daylight fluorescent and doesn't do justice to those colors...
    Here's a shot taken with a flash just to get an idea of the color depth
    tnt423, Barncaster, CFFF and 5 others like this.
  7. nnieman
    nnieman Tele-Meister
    ontario, canada
    They both look fantastic!!
    Nathan
    crazydave911 likes this.
  8. preeb
    Sonoran Desert
    Thank you. I really love the way both have turned out.
    Designing is one thing but seeing it come to life is overwhelming...
    like the difference between school Sex education and having your own child (-;
    Barncaster and nnieman like this.
  9. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    London, UK
    Beautiful build!
    When the body is hung it reminds me of Edvard Munch’s The Scream for some reason!
    Mxk116 and Scatter Lee like this.
  10. preeb
    Sonoran Desert
    Your avatar too... (-;
  11. telechadster
    telechadster Tele-Meister
    Vancouver
    Just beautiful! It just keeps getting better with each post. I absolutely love the shape and design, its personally taking some of my favourite elements and combining into one dream guitar!
    DaveNJ likes this.
  12. Jupiter
    Osaka, Japan
    Gorgeous as always!
  13. supersonicobr
    supersonicobr TDPRI Member
    Brazil
    Gil, you've read it repeatedly but I won't refrain from it: your level of resourcefulness and craftsmanship are as amazing as they are a privilege to witness.
    Parabéns e um abraço!
    BluesBlooded likes this.
  14. budgetbuild
    budgetbuild Tele-Meister
    virginia
    Stradivarius is alive and well and living in Arizona.
    Jim_in_PA likes this.
  15. preeb
    Sonoran Desert
    Thanks. I think (-;
  16. preeb
    Sonoran Desert
    Before the clear coat is sprayed the binding and nut sides need to be cleaned from the color coat
    I press a wooden maple straight edge on top of the frets
    and scrape with a sharpened piece of band saw blade I shape to size
    The creme dots look nice against the darker colors and I find them more visible on a dark stage than the dark dots in a creme binding...
    CraigB, Barncaster, nnieman and 4 others like this.
  17. preeb
    Sonoran Desert
    Headstock sprayed in black lacquer. I use a logo mask to make scraping easier
    Scraping the logo edges
    and tint with UV aged golden lacquer
    Stamping the body and neck with serials.. etc..
    First clear coat is a thin misty coat of Nitrocellulose to fuse the lacquer to the Shellac.
    I make sure there are no blemishes in the flat surface
    The following coat is going to be the final wet and thick clear coat (hot lacquer without thinning) to allow safe buffing but will only be sprayed tomorrow.
    Once dry it will receive a wash coat of misty retarder and buffed to high gloss the following day.
  18. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Lynchburg Tennessee
    They are beautiful!!
  19. preeb
    Sonoran Desert
    The second and final clear coat is done the old school way using hot lacquer without any added thinner. This particular lacquer is pretty thick in room temp and really needs a significant percentage of thinner to be sprayed but thinner is sometimes the enemy when it comes to blemishes so heating up the lacquer is making it flow nicely to be sprayed and helps it lay flat and shiny with minimal run chances. It will also lose less volume as it dries, minimizing shrinkage or lacquer pull at inside corners.
    Temp used is 100 degrees Celsius which is the boiling water point in my electric rice pot (-:
    It will cure for at least a week or until it stops to outgas (by smell) and then I will spray the retarder coat to make it glassy smooth.
  20. Jupiter
    Osaka, Japan
    GLOSSY!
