Wazzou
That is a good article posted by tele-savales (great name). Thanks for that.If they're out of phase it's not actually matter of uneaqual volume. It's how pickups are cancelling each other's signal. That creates weaker sound. Some like it, Peter Green was the famous user. Turning another volume down a little bit just alters how signals are cancelled, so it's perceived 'stonger'.
So Sbs, you are thinking that these pickups are INDEED out of phase I take it. I need to look for my compass. Question though: the neck pickup is a humbucker. I understand that it has opposite winding between its 2 coils for hum cancel, but what about the polarity thing? This wasn't fully addressed in the article for a humbucker. For the humbuckers, is the polarity typically in opposite directions between the 2 coils? If so, in this particular guitar, should the "south/lower" coil be in the opposite polarity direction as the bridge's polarity direction, for things to be in-phase?
When I look at the Seymour Duncan diagram, I would say yes the "south coil" of the neck HB should have reverse polarity to my bridge pickup's polarity, for them to be in-phase.
The best case, one of the pickups have separate ground, then it's posdible to flip leads without grounding issues. CuNiFe doesn't have that.
You are right, there is only one lead and one bare wire for the cunife pickup, unfortunately.
