Wazzou
Hello,
I have a 2011 AVRI '72 Telecaster Custom. I just installed the CuNiFe WRHB reissue in the neck position. The bridge pickup is still the stock pickup (I love it). Since I was under the hood with a soldering iron, I decided to upgrade pots/caps/wiring:
*For the neck pickup I installed 500k pots
*For the bridge, new 250k pots
*All pots are CTS audio taper (more on this in a minute)
*.022 Orange Drop caps
*I replaced all wiring from the switch and jack and between pots to Gavitt cloth covered wiring
*Installed the new WRHB. DCR is 10.41
I really like this new neck pickup over the stock fake WRHB that came with the guitar. But there are a couple of questions I have:
1) Is it ok that I installed non-matching pots? Since I went to 500k in the neck should I have done the same with the pots for the single coil? I ask this because in the middle position, the volume/output is weaker than in either the neck or bridge alone. I have to turn the Bridge volume down to 9 to get the output to match the either the neck or bridge positions alone. My guess is that the neck pickup is dominating at that point.
*I think this might be because the pots are not the same. Thoughts?
2) I realized the hard way that linear pots are better for volume. Below 7 or 6, the volume dials are useless.
3) I've read that the new reissues of these guitars (American Original 70s) and the originals have 1-meg pot or pots in them.
*Can someone tell me if only the neck is a 1-Meg or are both volumes 1-Meg? Are all 4 pots 1-meg? I ask this because I feel that the neck pickup is still a little dark with the 500k pot. I want this guitar to be spec'd like the originals and reissues.
Finally, I've read some threads on here about people's experiences with the WRHB reissues. I agree that the low stings (E/A) get flubby/too bassy when I crank my amp past 5. I have a Princeton Reverb RI. Really, the problem is the Low E. When playing A string power chords, it's not really a problem. Is there anything that can be done about this? Maybe the WRHB is just not really good with amps in the breakup zone, as Telenator has said in his comments to these threads, though I would say when I don't include the Low E it sounds great at those volumes. Plus, there is always the SC in the bridge, which is REALLY good at breakup.
Thanks for your comments!
