New bullet dilemma
Discussion in 'Squier Tele Forum' started by bls82261, Feb 25, 2020.
  1. Switchy
    Switchy Tele-Holic
    Arizona
    :lol::lol::lol: It's ME that's been looking at loaded pickguards for strats!
    But loaded tele plates are dirt cheap too.
    nicod98 and LutherBurger like this.
  2. Jlwctn
    Jlwctn Tele-Meister
    Indiana, USA
    Did you shoot any contact cleaner in the switch?
  3. bls82261
    bls82261 TDPRI Member
    Virginia
    I did try the detox thing. It didn't make any difference. My next attempt is going to be desolder the yellow wire, cut it back a bit and resolder. If that doesn't work then a new switch it is.
    Thanks for all the replies.
  4. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    My switch was bad when I received it -- one of the lugs was loose and only provided intermittent contact. I replaced it.
    If you determine that your switch is good and only the solder joints are bad, I recommend ditching that skinny little bridge between them (it will fall off when you touch it with the soldering iron) and soldering the pickup wire directly to both lugs.
    bls82261 likes this.
  5. Mind Flayer
    Mind Flayer Tele-Meister
    Chicagoland
    Btw, I played one of these bullet teles yesterday, the surf green one. I was really surprised at how thick the neck was! It felt great! I don’t need any more guitars, but these seem like a really good deal.
    bls82261 and Fendereedo like this.
  6. bls82261
    Virginia
  7. LutherBurger
    NYC
    I used an old box switch in mine. As far as I know, any 3-way blade switch will fit -- box or open -- because their mounting holes are all the same distance from each other.
    Some box switches come with oval head screws, though, and their heads will stand above the surface of the plate because the holes in the plate aren't countersunk.
