New bullet dilemma
Discussion in 'Squier Tele Forum' started by bls82261, Feb 25, 2020.
  1. bls82261
    bls82261 TDPRI Member
    Virginia
    I bought a bullet tele of MF last week. I know it's a cheapo but I really like it and have already started to bond with it. Everything was fine this morning but this afternoon I have no power in the bridge position. I don't think its the pup, I think it's the switch. I get the "normal" tone change between the middle and neck position.
    I bought this guitar for a couple of reasons. I wanted something with some twang but I also wanted something inexpensive I could learn to do setups and minor repairs on.
    Musicians Friend says of course they'll exchange it but if I try to repair and am unsuccessful then there will be a restocking fee.
    I have zero experience with guitar wiring but am at least semi handy.
    So, do y'all think I should tackle this myself and take a chance on blowing up my warranty or just exchange?
    Thanks
    Fendereedo likes this.
  2. Mind Flayer
    Mind Flayer Tele-Meister
    Chicagoland
    Probably just a bad soldering connection. If you really like the guitar and don't feel up to the task, you could take it to a tech for a quick look; if it's just a bad solder joint, any remotely competent tech should be able to fix it quickly and cheaply.
  3. Mind Flayer
    Chicagoland
    On second thought, if one of the reasons you bought this was to learn how to do repairs, then I guess you ought to just try and fix it yourself. There are some youtube videos on how to solder guitar wires if you're not familiar with that. Worst case scenario, you can't fix it, just take it to a tech, should not be an expensive fix.
  4. bgmacaw
    bgmacaw Friend of Leo's
    Near Athens GA USA
    Do you have a soldering iron and do you know how to use it?
    Do you have a multimeter to test the circuit? You don't absolutely need to have one but it helps.
    It's pretty easy to swap out a switch although the stock switches they put in Bullets aren't all that great. I'd upgrade the switch while you're in there or at least do it eventually.
  5. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    Alrighty, then. :)
    Unscrew the control plate and flip it over. Find the wire that runs from the switch, through a hole in the wood, toward the bridge. I think it's white.
    The wire should be connected to two adjacent lugs on the switch. Is it? And if you wiggle the wire, does the bridge pickup come back on?
  6. Switchy
    Switchy Tele-Holic
    Arizona
    It's probably pretty obvious, I'd give it a try, and worst case.... LIE and say you didn't.
    CavalierX, skitched and Fendereedo like this.
  7. tery
    tery Poster Extraordinaire
    Tennessee
    Exchange it .
  8. gregulator450
    gregulator450 Tele-Holic
    The Dry Side
    You bought it to learn repairs; likely it's the switch or a bad solder joint, and not the pickup. This is a perfect time to learn how to replace that cheap switch with a better one. It will only cost you a few bucks to get a soldering iron and the new switch, and you're well on your way to being your own repairman. ;)
  9. Fendereedo
    Fendereedo Poster Extraordinaire
    Buy yourself a Weller soldering iron, some solder and a soldering station and get over to YouTube, and learn to solder. After a while it will become second nature to you. You will get some burned fingers along the way, but that is all in the learning process.
    skitched and Footsore like this.
  10. Footsore
    Footsore TDPRI Member
    I bought a Squier Thinline a few weeks ago which had the same problem out of the box. It was easier for me to replace the switch than send the guitar back so I did.
    In your case though it may be different and you may be better off exchanging it.
    Those switches though are really weak and would be the first thing I would upgrade anyway.
    Perhaps get yourself a new CRL switch a soldering kit and some wire and have a practice at soldering before pulling the control plate off. A few videos instructions should help.
    Fendereedo and mkdaws32 like this.
  11. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
    Put in a four way switch.
    Should be stock anyway.
    gregulator450 likes this.
  12. Danb541
    Danb541 Tele-Holic
    Oregon
    You bought a cheap guitar so you could learn how to work on guitars. The cheap guitar stops working correctly. Seems like exactly what you wanted to me. This should be an easy fix, you can do it.
    bls82261 likes this.
  13. Switchy
    Switchy Tele-Holic
    Arizona
    Also, you can buy a replacement Squier pickguard, LOADED for like $25.00 bucks... so you can't really go wrong no matter what you do.
    *And a cheap chinese one is like $15.00*
  14. Fendereedo
    Hi was it a CV 60s thinline you bought? It's really odd, some of the new CV models have them old crappy switches still, and some have the type used on the MIM Fender models. Luckily mine had the latter switch. The only thing I've changed out that I've found was duff was the jack socket, I unsoldered the stock Jack, and then added a Fender one with a screw in jack plate from Allparts. I do that to all my Tele's though.
  15. Dan German
    Dan German Poster Extraordinaire Silver Supporter
    Left of the Left Coast
    At the very least, open it up and take a look. Very possibly, there will be a broken wire. Easy peasy. If everything is connected properly, and it still doesn't work, then think about returning it. Just looking inside won't have any effect on warranty.
  16. bls82261
    Virginia
    I'm gunna keep it and give it a go. I think I've narrowed it down to the yellow wire near the switch. The solder joint itself seems solid but the problem seems to be in that area. Maybe even broken wire at the kink you see.
  17. Footsore
    Mine is a CV70s from Indonesia. Good Alpha mini pots but a really crappy switch. I think if you're going to buy cheap electric guitars you have to know how to do some basic soldering. YouTube is your friend.
  18. LutherBurger
    NYC
    He could certainly go wrong, if he followed advice to buy a loaded Strat pickguard for a Telecaster. ;)
    skitched and Switchy like this.
  19. Fendereedo
    Totally agree there. I've got the same mini pots, and in all fairness they are pretty nice so far. You're right about cheaper guitars though, when I had my Squier VM Jag, there were a few loose wires which needed re soldering. Like you've said, it's just part of the process of buying cheaper, and something to be expected.
    Footsore likes this.
  20. LutherBurger
    NYC
    OK, the wire is yellow, not white. My mistake.
    The lug that would cause the problem you described is the third one from the bottom, so focus your attention there.
