theprofessor
Finished the back panels. Now for sound samples...
I didn't know you were the one who posted that new layout! It was SUPER helpful! Thank you. I agree that this amp is remarkably good sounding. I think I'm going to stick with a 6L6 in there for now, at least. My first-ever amp was a 5f2-a, and I've built a couple of 5f1's, so I know what a single-ended 6V6 amp based on that topology sounds like.That is looking really good. Have you really cranked it? A 6L6 in there stays clean and it's bright-sounding. Pop a 6V6 in and try it; it gets some really good grind going when cranked and is warmer sounding.
The layout you posted in the OP is the one I published as the change to Hunter's original 2-stroke. I built it and stuck it into a tweed head, but I figured it deserved to be a combo so I stuck it into a big Bluesbreaker-sized 1x12 cab with a Celestion greenback in it. The '63 Ford Falcon Futura badge adds real vintage toneIt's the best-sounding amp I've made thus far.
Thank you! I like Tube Depot and Doug Hoffman's store. For the chassis, I used Mojotone. Those are my go-to places for sourcing amp parts.Well-done project. I’d like to try building an amp when I retire (hopefully next year). Any recommendations for part sources?
Thanks, professor. I’ll check them out.Thank you! I like Tube Depot and Doug Hoffman's store. For the chassis, I used Mojotone. Those are my go-to places for sourcing amp parts.
Thanks! It's Rust-Oleum Multi-colored Textured Spray paint. Autumn Brown. It looks a lot like leather or stone, and it's rough to the touch. Very difficult to apply, but it's a cool and unique finish, in my opinion. It should be super tough, too.Nice, what is that coating?
What is the difficulty in applying the textured paint?Thanks! It's Rust-Oleum Multi-colored Textured Spray paint. Autumn Brown. It looks a lot like leather or stone, and it's rough to the touch. Very difficult to apply, but it's a cool and unique finish, in my opinion. It should be super tough, too.
It is finicky in terms of how it lays down, due to the texture in the paint. These cans have to be shaken quite thoroughly, and the temperature suggestions for application should be followed pretty strictly. Due to the texture, the nozzle is big, and that means that you blow through a can really fast. If too little texture comes out, you're getting only the base color. And you have to spray from a greater distance than is typical for regular Rust-Oleum spraypaint, to avoid pooling.What is the difficulty in applying the textured paint?
Thanks!It is finicky in terms of how it lays down, due to the texture in the paint. These cans have to be shaken quite thoroughly, and the temperature suggestions for application should be followed pretty strictly. Due to the texture, the nozzle is big, and that means that you blow through a can really fast. If too little texture comes out, you're getting only the base color. And you have to spray from a greater distance than is typical for regular Rust-Oleum spraypaint, to avoid pooling.
Thanks for that! I was having a heck of a time finding the outer and had given upOne thing you can do with that is to clip the cap in, wrap one hand around the AC cord running to the amp, and gently pinch the cap with thumb and finger of the other hand. You will hear a difference that way.
