theprofessor
I've become interested in a single ended "big bottle" amp and have decided to build the revision of the Dave Hunter "Two Stroke" (in his great Guitar Amp Handbook) that has one power tube. I think I'll call it the "Single Engine." I have been helped so far by looking back at some of @jsnwhite619 's threads and posts on his "big bottle" 5f2-a, in which he used a 5881 (e.g., here and here). I may also do that, but I think I'll try a 6L6GC first, as I've got a couple of vintage singles of those already.
Parts I'm using/ things I'm doing:
- Here's the layout I'm using. I won't have multiple speaker jacks or switchable NFB, but I am going to include the boost and cut switch on one of the inputs.
- Turret board: I've started building my own turret boards out of glass epoxy board and Doug Hoffman's nice turret lugs. This is my first one. It allowed me to design the layout I wanted and then drill the holes and install the lugs. My layout is very similar to the one in the layout I'll post here, with a few changes to allow for keeping two many leads out of one turret and also to fit the size of the parts I am actually using. I've decided to copy Hunter and use a single bus this time. We'll see how that works. I'll probably copy @jsnwhite619 's filtering scheme, though, with a 30μF-22μF-22μF string. My board is 8-1/2" x 3".
- Mojotone 5f2-a chassis.
- Hammond 290AX power transformer. I've used this PT a lot, and I like it. It has a 6.3V heater center tap, which I'll terminate at pin 8 of the 6L6. It also gives me 3A current on the 5V heater winding, which I like, because I like using 5U4 rectifiers. I'm going to do that on this build, and I already have a couple of vintage ones on hand. It makes no sense to me to use a 5Y3 with that much power stage filtering and a single 6L6 tube. In general, I do not like the sound of amps with a 5Y3 -- or at least I prefer a 5U4 (conversely, I also often find a GZ34 to be too "stiff"). I'll use the 325-0-325 high voltage winding. This PT can produce up to 100 mA current.
- Hammond 125ESE output transformer: This thing is a beast! It is heavy, and because it is a universal single-ended OT, it has four secondary windings. That means a lot of wires to go through the chassis punch-out. I had to enlarge that hole with a step bit to fit all of them through. I'm planning now to use an 8 ohm speaker. That will be one of the puzzles I've got to work through: the best impedance ratios for the tube and the speaker. I'll need to review how all that works again.
- cabinet: I'm building my own cabinet out of 3/4" void-free baltic birch ply. Roughly 20-1/2"w x 18-3/4" h x 9" d. Planning on a 1/2" baffle made of the same baltic birch and hoping to get a 12" speaker cutout to fit in there.
- speaker: I'm planning on a vintage Oxford 12T6. I really like this speaker. I've had one in my vintage Deluxe Reverb, and I'm looking forward to hearing how it sounds in this very different amp.
I welcome all feedback! I have much to learn!
