ElliotKnapp
I just officially embarked on my 19th amp build and I thought it'd be fun to document the process a bit more than usual and note some observations and preferences developed over the last few years and builds.
The project: a ~35 watt "black panel" Fender combo based on a Princeton Reverb-sized Weber 6A14HP chassis and higher-powered transformers, with a 15" Weber 15F150 speaker. Weber's 6A14HP circuit is basically a 6L6 Princeton Reverb, but I decided to go with a few other particularities: foregoing any kind of tremolo and using the spare 12AX7 triode for a long tail pair phase inverter; using the spare trem potentiometer holes for a mid control and a master volume bleed control before the PI. So, really, it's probably more similar to a single-channel AB763 Vibroverb (er, except without the "verb" part), but so much has been removed that it's kind of neither here nor there.
I'm so far from "needing" another amp at this point that I have to come up with esoteric excuses for embarking on a new build--this time I've strung a few together: 1) the fact that I have a spare Weber 404248 output transformer on hand, 2) I've got a 15" alnico Blue Dog that I use and love with my 5F6-A, but I haven't loved it with my black panel circuits, so I "needed" a new cab with the black panel "preferred" 15F150 to see if I like it better...if I'm going to have another speaker cab, why not shove another amp chassis in there?, and 3) What would a high power black panel with a 15" sound like with KT66 output tubes instead of the specified 6L6s? The KT66s are the riskiest component, since I'm still not sure if there's even room--I attempted some math based on Weber's chassis drawings and things seemed to add up, but I won't know until the chassis and power transformer arrive and I can fit check, so it might be a 6L6 build instead! Bottom line: it's just fun to have a new project.
To develop and verify my layout I used the Weber 6A14HP layout and power section, the AB763 PI, and this handy tremolo-free layout with a master and mid control from the ever-generous Steve Luckey over at the Hoffman forum. Attaching my rough-and-ready DIYLC layout here, which is a few generations removed from one available on Robrob's site. Not exact for what I'm doing in terms of all of the components or the precision of the layout (and there are some vestigial voltages and other info that's not relevant); I'm using it as a reference with everything in one place.
A couple days ago I started the build. With almost all of my builds except tweeds ≤5E3, I favor turret board construction and I make 'em by hand, so I started with laying out the board via template. The first few boards I built years back, I laid out by punching through the existing holes of a fiber board for the amp--didn't work great, since the vertical turret offset makes a significant difference in how the components can coexist, so now I do it by hand on paper using actual components--works for me and it's nice to have the template available for future builds.
I usually buy my blank 3mm G-10 boards from Tubedepot, but Amplified Parts now carries the material and I was able to get everything else I needed in one order from them, so I gave theirs a try. What I don't love is that their board pieces are 11 7/8" x 7 1/16" (whereas Tubedepot's are 3" by whatever length you want--they cut it). I had to get it down to 11" x 3" myself, for which I don't have the best tools (a Dremel). So, the edges are a bit "rustic."
Tape the template on top, center punch the holes, and it's off to the drill press. Amplified Parts' 3mm turrets need a ever-so-slightly-larger-than 2.5mm hole. I used to just use my 2.5mm bit and call it good. If you do that, it's pretty tough to line up the turret with the hole and if you're like me you WILL get some bent, destroyed, or even broken-off turrets trying to line them up and hammer them in with the anvil and staking tool. So nowadays I drill 2.5mm holes and then kiss the top of each hole with a 3mm bit. It makes a huge difference in ease and speed of installing the turrets. While it's still a somewhat tedious endeavor pounding each turret and then flipping the board to press the ends, it's always satisfying to see the finished product.
FedEx delayed my cab and chassis packages until today, so I spent yesterday adding leads and components to the board...more in the next post.
