New bass build - Spinal Back2back bass
Discussion in 'Tele Home Depot' started by Mbechmann, Oct 16, 2015.
  1. Mbechmann
    Mbechmann Friend of Leo's Ad Free + Supporter
    Grindsted, Denmark
    Yesterday a very good friend of mine broke my heart. He is selling his bass due to 2 back spinal back herniations. He simply cant play bass anymore.
    I want to find out if it is the weight that is causing problems. If it is, then I will build him a second version of my travellers bass - the short scale (20") headless bass.
    Right now here is what I am thinking:
    1. Body - Puplar or Cherry
    2. Set neck using laminated neck - maybe poplar and bloodwood
    3. Hardware - not sure yet but it will be specialized strings like my headless bass
    4. Pickup system will be a mixture of piezo and something else - single pickup somehow.
    5. The finish. Not sure yet. Dont want to paint it (I am not a great painter) but I may want to stain it. We will see what happens
    As for the shape I am thinking original design somehow. I have an idea that I might use for this one.
    The time frame is that I am hoping to be done by Christmas.
  2. oldrebel
    oldrebel Friend of Leo's
    Lynchburg Tennessee
    Michael this sounds like a great idea. What a good friend you are.
    I'll be watching. Good luck!!!
  3. Mbechmann
    Grindsted, Denmark
    Well it just breaks my heart knowing that the guy that got me started in playing bass, no longer is playing - and I could have done something about it. Thats just not in my nature to do that.
    As for the design. Here is a little bit of where I am coming from. The design is a second version of the Cobranita I did back in 2014 challenge.
    The reason I am thinking on expanding the horns is because I want to move the whole bass scale much closer to the body - or actually if you hold it towards the right side - like cigar box style bass. I might actually go long horns as well.
  4. mindwave
    mindwave Tele-Meister
    orlando
    sounds like a winner, have you thought about a semi hollow or full hollow bodied instrument?
    Beatle Bass could be small and hollow!
  5. Mbechmann
    Grindsted, Denmark
    I am thinking more the line of a thin-line. But since the whole bass is small I am not sure it will work.
    1 thing I have been thinking is that the design above wont work. It will cause him to play slightly to the left. Thats no good. I will move the scale more left.
  6. Mbechmann
    Grindsted, Denmark
    Here is what is going to be the prototype for this one.
    http://www.tdpri.com/forum/tele-home-depot/521263-headless-bass-build-help-needed-5.html#post6636086
    I also had a talk to him today about this bass. At the time he didnt know what I had planned. I asked what the problem was - and it was the weight that is the main problem. But it does also hurt to play the deeper notes on his normal bass. So the twisting/stretching is an issue.
    That does clarify the design a bit. The prototype is 1.780kg. I am hoping to en up around 1.2-1.3kg. It will be tricky but thats my goal :D
  7. Larkins
    Larkins Tele-Meister
    Bay Area, CA
    What about something along the line of a Ubass? They make solid body ones that are like a 20" scale. I've been planning on building a version of one of those for a while.
  8. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Great project, Michael! Given what he's told you, I'd say your original version would be a winner: light and with not as far to reach.
  9. Mbechmann
    Grindsted, Denmark
    The ubass was the reason I build the travellers bass in the first place. It is the strings for a ubass I am using. But a ubass is still around 2.2kg in weight. I am aiming much lower :D
    I have been playing with a design where the top horn is longer then normal. That should help the strap from being a problem as well.
    I am thinking about going laminated body - just to add some strength into it + either champering the inside or actually making it see through - holes straight through the body.
    I am however just not sure what types of wood to use. Poplar and mahogany is too close to actually add strength. So I need something that is strong, and light weight... Just not sure what to use... I have access to bloodwood but thats about it.
  10. Mbechmann
    Grindsted, Denmark
    So here is the design I am thinking on. Its approved by my friend. I like it as well :D
  11. Mbechmann
    Grindsted, Denmark
    Have been doing a bit of design work on this one. Changed the wood. The mahogany pieces was on the heavy side - which to my surprise puplar was as well.
    So now the neck will be a 3 piece neck through with mahogany and redwood pine. I had a piece that was perfect in weight so that will work. I went from 1970 gram to 1460 gram by doing that.
    I also found a guy here in Ireland that will make both the bridge and headpiece out of alu instead of iron. The china one I have is 670 gram so we need to cut the weight there.
    Finally I cut the pieces out. It is really small :D. 55cm long. I will do a bit of sanding before glueing the pieces together.
  12. Mbechmann
    Grindsted, Denmark
    Headpiece almost done. Made in Alu to keep the weight down. The screws is Alan keys so they will tighten the strings without breaking it.
    Still need to paint it black.
  13. I_build_my_own
    New York
    That's a very nice end piece!
  14. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    Love the bridge, I do not know much about basses, are only two screws going to keep it in place?
  15. metecem
    metecem Friend of Leo's
    Dierberg, Rheinsberg, Germany
    I'd find a way to polish that piece and keep it polished. I would not paint it. Great work has to be seen.
  16. Mbechmann
    Grindsted, Denmark
    I cant take full credit for it. Together with a friend of mine we designed it and he build it. He is the metal genious :D
    Well, its not the bridge to start with. :D Its a headless bass so this is what the headstock will look like. The 2 big holes are for fixing this to the neck, yes.
    I asked my friend what he preferred and he likes the black. Personally I like black, but love this polished alu. Its not the last time I use this type of bridge and nut.
  17. Mbechmann
    Grindsted, Denmark
    All painted black. It looks good. I like both the silver look and the black look.
    He is now starting work on the bridge. This is going to be good
  18. oldrebel
    Lynchburg Tennessee
    That looks great!!
  19. Mbechmann
    Grindsted, Denmark
    I think he is doing an outstanding job. Cant wait to see them on the bass.
  20. Barncaster
    Northern California
    Excellent work Michael on all levels!!!
