New amp soon: Tweed Champ or Tweed Princeton??
Discussion in 'Shock Brother's DIY Amps' started by richon, May 6, 2009.
  1. richon
    richon Tele-Meister
    Viña del Mar
    I'm into building a New amp soon: Tweed Champ or Tweed Princeton??
    both are very similar except the Tone control that could be switcheable.
    any reason to avoid the Tone control?
    Besides the circuit I plan to use a Weber 8A125T and a handbuild Pine cabinet.
  2. ThermionicScott
    CID
    Tweed Princeton, hands down. No more difficult to build than a Champ, just a couple more connections to make, and it's more flexible. Sounds better with the bigger cabinet too, IMO. I love mine!
    - Scott
  3. sjhusting
    sjhusting Tele-Afflicted
    Germany
    The tone control causes a certain amount of signal loss, which is why the cathode is bypassed on the first stage on the Princeton, to produce more gain going into the tone circuit. You can make both switchable, the tone control and the bypass, then you have both amps.
    You could also think about putting a switch on the NFB so you can remove it completely. And you could add an extra 47 ohm resistor between the 1.5K on the second stage and ground, and add a (switchable) bypass on the second stage over the 1.5K only. This way you can bypass the second stage (more gain) and still keep your NFB. See the BF champ for an example of this
    You could also add a choke to the power supply. See the 5f2 (no A) schematic.
    steven
  4. richon
    richon Tele-Meister
    Viña del Mar
    I plan not to use a Choke. Use a NFB switch (although i guess I will have it always off). A tone switch... and maybe the bypass cathode switch.
    beside the bigger cabinet... just amp-wise..... both sound the same?
  5. bluesfordan
    bluesfordan Friend of Leo's Silver Supporter
    Nashua NH
    not so sure why one wouldn't bother going with a 12" speaker if you're making your own cabinet. One of the things that bothers me the most about these amps (the real deals) are the small speakers. To my ears, single speaker amps sound better with a 12. Two 10s sounds better than one 10 ie Vibrolux. Since it is going to be a homebrew, total vintage authenticity is not crucial. Just my humble opinion.
  6. Paulie13
    Paulie13 Tele-Holic
    Columbia, SC
    I second this.
  7. sjhusting
    Germany
    12" speaker - yes, makes a big difference
    steven
  8. ThermionicScott
    CID
    I'll third (or fourth) it. A 10" in the Princeton-sized cabinet is a noticeable improvement in sound, and a 12" in a slightly-bigger cabinet should be even better.
    - Scott
  9. FiddlinJim
    FiddlinJim Tele-Holic
    Seee-attle
    I did some experimentation with NFB on the 5F2A Princeton I built a while ago. With no NFB, it felt really uncontrolled (some unexpected oscillations, I suspect) and was just a little too wild for me. I experimented with a few different values and came back to 22K as it sounded the best to me. I guess Leo got it right the first time. Where have I heard that before?
    There was a thread a while back singing the praises of the 8" speaker in that bigger cabinet vs. a 10" or 12". Many people feel that's one of the "magic" things about the Princeton. I experimented to the point of cutting and clothing a new baffle. I liked it OK, but grew to disagree with the "magic-ness" of it and went back to my 10" speaker. I was also comparing an Weber alnico "sig" series 8" with a higher-end Weber 10" alnico, so it may not have been a fair fight.
    Every time I play the Princeton, I think sounds a little better. I'm an edge-of-breakup as opposed to full cranked snarl sort of guy.
    dnauheim likes this.
  10. richon
    richon Tele-Meister
    Viña del Mar
    so you guys thinks building a DIY Tweed Princeton amp is a waste if i don't use a 10" just because I can?
    what if i wan't that boxy nice sound and portability?
  11. ThermionicScott
    CID
    Yeah, pentodes and beam power tubes aren't as linear as triodes, so even when it's not clipping, there's going to be a lot of extra harmonic content without negative feedback. When you have a push-pull pair, they'll even out each other's nonlinearity to some degree, so you can get away with using less or no feedback. Leo knew what he was doing. ;)
    Totally! And that's the way I love to play mine -- loud enough to get some hairy cleans, but not to the point where it gets all ratty and buzzy sounding. I dunno if the amp is sounding better, or if I'm adjusting my playing around what sounds best out of it...
    - Scott
  12. ThermionicScott
    CID
    I don't think it would be a waste -- build an extra baffle and try it both ways! The 5F2A is a little bigger than a Champ, but I'd say they're equally portable. Here's my 5F2A next to a blackface Champ:
    - Scott
  13. ruger9
    ruger9 Poster Extraordinaire Ad Free Member
    Hackettstown, NJ
    That's what I'd do: build 3 baffles & try them all. Yeah, it's more money if you don't have the extra speakers lying around, but it would be a cool experiemnt, a learning experiment, and in the end you would have the amp you want.
    Or, it could just make the decision harder because they'll both sound good, just different. I've had THAT happen before. Kind of like "boy, I wish I hadn't gone there!" type of thing.
    Personally, I think the 8" rocks. The Valvetrain 205's (%f2A) have the Weber Alnico S in them, and sound awesome. And that's what a 5F2A IS. I might consider bumping up to a 10", but IMHO a 12" makes it no longer the same amp. It's all personal preference tho.
  14. richon
    richon Tele-Meister
    Viña del Mar
    so, a good 8" (like a Weber 8A125T) would sound really good as a Princeton Tweed speaker?
    do any of you have a demo of your tweed princetons to look at? (both 8" and 10" )??
  15. premiumplus
    premiumplus TDPRI Member
    michigan
    It's funny, I've got a 1960 Princeton tweed, and it had a Radio Shack speaker in it when I got it. I put in a top of the line Weber 8" alnico in it and didn't like it. I went to the ceramic Weber and it was okay, I guess, but I still wasn't impressed. A lady at another forum suggested a cheap Jensen MOD 8", the one that used to sell for $16 or $18. I bought it for the heck of it, and lo and behold, it sounds GREAT. I'm going to buy a couple more for my Silverface Champs, it sounds so good. YMMV of course, but I was really blown away at how good that cheap Jensen sounds.
  16. ruger9
    Hackettstown, NJ
    yeah, speakers are really a personal thing- there is no "best" or "as good as".
    What did the originals have? Jensens? If so, you might be able to get a Jensen 8" Alnico (?)
  17. TNO
    TNO Friend of Leo's
    NC-USA
    Having built the 5f2a and the 5e3 I'd say just go ahead and do the 5e3. Much more useful amp and it would only take about an extra hour to wire up.
  18. richon
    richon Tele-Meister
    Viña del Mar
    I allready have a 5E3 HEAD and 2x12" alnico cabinet...
    so now for good sound, but portability.
  19. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Fullerton, CA
    I'd go Princeton... Champs aint bad, but as mentioned you could add a switch or two to make it go Champ or Prince.
  20. richon
    richon Tele-Meister
    Viña del Mar
    JOHNNY , you have a TON of CHAMPs and his rocking brothers..... where to go? 8" o 10"??
