forrestlaw
Deciding between the following amps:
Carr Skylark
Carr Telstar
Suhr Hombre
Victoria 20112
Victoria Vicky Verb
Vintage Sound VSA 15 or 20
Back story... I have a TM DR that I thought was OK until I heard a Tweed Deluxe circuit, which set me looking for a new amp. I went into a shop that stocks all of the above brands to try some out and liked everything I tried MUCH better than the Tone Master. Even though I fully thought I might walk out with a 20112 (Tweed Deluxe circuit) I also tried a Vicky Verb, which I actually liked the best, and Telstar on the recommendation of the sales guy. I did get a little scared of the Vicky Verb being only 5w, though. After doing a little more research I've added the Skylark, Hombre, and Vintage Sound to the possibility list even though I didn't get a chance to play those, which is why I'm soliciting opinions and comments based on TDPRI user experiences.
I play almost exclusively at home, but would like the option of taking my amp out to a small gig. Both of my guitars are Teles, a Chrissie Hynde signature model and a Vintera 50s that's been converted into an Esquire. I'm a plug and play guy... I've spent alot of money trying to be a pedal guy, but that's not me. I do like and use a good big muff and TS style OD. I don't want alot of knobs on an amp, just give me something that sounds good that I don't have to fiddle with. I wouldn't say that I'm after a particular sound, but I do like the older Fender amp circuits based on videos I've seen.
Here's what I thought of the amps I tried:
Carr Telstar: Simple knob layout and full range attenuator. The two switches gave alot of versatility. Didn't really care for the look. Ultimately, probably not what I'm after.
Carr Skylark: Didn't test this one. Sounds good in demos. More knob and attenuator only goes from 0 to 10 percent. Seems to be a recreation of small 60s Fender amps.
Suhr Hombre: Didn't play this one, but am super intrigued. Super simple controls and seems to sound great at almost any volume in demos. No reverb... not a dealbreaker though.
Victoria 20112 (Tweed Deluxe): This is the one I thought I was going to walk out of the store with. Sounded good, but I am worried about home volume levels.
Victoria Vicky Verb: This was the one I played that I liked the best. 5w with a half power switch, so seems almost perfect for home use. Tubes can be switched out to provide more power and clean headroom. Likely leaning this way.
Vintage Sound 15 or 20: Didn't try this one. Princeton circuit, basically.
Thoughts/comments from anyone that's had a chance to play one or more of these?
Carr Skylark
Carr Telstar
Suhr Hombre
Victoria 20112
Victoria Vicky Verb
