New 5F2A build
Discussion in 'Shock Brother's DIY Amps' started by HBamps, May 28, 2020.
  1. HBamps
    HBamps Tele-Meister
    Alameda, CA
    It’s been several years since I built an amp from scratch and decided on a simple, low power and volume, classic. The only mods I plan to do is to add a Framus mid control and omit the tone control, for now. I want to see what the high end response is without the 5F2A tone control and possibly add it, or a simpler treble roll off circuit.
    Since being stuck at home, a 5W amp seems like the perfect thing for both low volume playing and to keep my mind busy.
    All parts purchased and on there way to me. I thought it’d be fun to do a little diary on the build to document all the challenges and successes.
    More than just a pile o’ parts. Here’s the first bit of real progress. I measured the components and drafted the board in ACAD, printed to scale to get the template for drilling for eyelets. I could of bought one of the board options from mojotone but wanted to do it myself.
    getbent, monkeybanana and King Fan like this.
  2. King Fan
    Salt Lake City
    I admire all the skills on display here, CAD, beautiful DIY board, etc. Envious, me.
    But is the board photo flipped L<->R? Or did you wire up the wrong side? Hmm, wait, it's like a Hendrix lefty guitar. No, I'm missing something here... :):):)
  3. mjcyates
    mjcyates Tele-Meister
    Louisville, KY
    I just built one of these with the Framus Mid Control and the normal Tone Control. They actually work pretty good together.
  4. Lowerleftcoast
    california
    I think your bias cap is backwards. Unless you have the board wired differently than stock.
    EDIT: oh I see you do have it wired different... never mind. But why?
  5. HBamps
    HBamps Tele-Meister
    Alameda, CA
    Haha, yeah the board does look backwards! I took the Hoffman layout, which is kinda weird but really ingenious actually, I just changed the preamp a little.
  6. HBamps
    HBamps Tele-Meister
    Alameda, CA
    Progress. Got all the heaters (don’t miss that at all), rectifier and power wired. Board mounted. Wiring in pic looks a little messy but haven’t tidied up yet. I’m hoping I can get things looking clean for the finished product. These little tweed chassis are tight little suckers!
    tizianod likes this.
  7. HBamps
    HBamps Tele-Meister
    Alameda, CA
    I got this amp running and, with some tweaks, I think it's sounding really great. I am still searching for a speaker that I really like but thru a 1X12 cab it's sounding really great.
    I ended up with the following signal path. Input -> V1a -> Vol -> Framus Mid -> V1b -> high cut tone control -> 6V6. When I had the high cut following the mid control I felt it affected the taper too much and with it after the next gain stage, it's doing what I want (just shaving some highs).
    I also experimented with cathode bypass caps on both V1a and V1b and found I am liking both unbiassed the best so far. Second fav was just V1b. I guess Im a rebel.
    I am awaiting shipment of a Eminence 1058 hoping it'll give me something closer the low end of a 12.
    Anyhow, this is a really fun amp and sounds great at low volumes. I have wanted a good amp for quiet home practice and when I play with singer/songwriters. I think this is going to be a perfect solution!
  8. mjcyates
    Louisville, KY
    WGS G10C will give you the low end of a 12".
  9. HBamps
    HBamps Tele-Meister
    Alameda, CA
    Thanks for this tip. I'll keep it in mind.
  10. HBamps
    HBamps Tele-Meister
    Alameda, CA
    This amp is pretty much complete. I still want to refine the treble response and gain but it's sounding pretty good! Here's a clip, note that I am using OD pedals, as pretty much always do.
    keithb7 and Tom Kamphuys like this.
  11. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    I’m also trying to sus this out on my 5F1. Do you have both of these on a mini toggle switch, or did you audition them in and out of the circuit while playing?
  12. James Knox
    Phoenix
    Beautiful tone. What pedal do you use in this clip?
  13. HBamps
    HBamps Tele-Meister
    Alameda, CA
    alligator clips
    James Knox likes this.
  14. HBamps
    HBamps Tele-Meister
    Alameda, CA
    I am using a JHS Morning Glory, JH Fuzz Face with the volume rolled back on the lead part, delay.
