new 5E3 build volume problem
Discussion in 'Amp Central Station' started by ouaouaron, Sep 8, 2019.
  1. ouaouaron
    ouaouaron TDPRI Member
    Saint Louis
    Just finished my second amp, first was a 5F1 with no problems. this one is a 5E3 using TubeDepot circuit board. volume on amp and on guitar must be at 11 or 12 for there to be a little bit of sound out of the speaker. I tested several things and found that all four 68k (correct according to color bands) resistors are testing at 35k. Could this be the problem? How could they all be equally bad? seems like a parallel reading but it is a circuit board with each having their own separate holes. thanks
  2. corliss1
    corliss1 Poster Extraordinaire Platinum Supporter
    Lansing, MI
    Just because they have separate holes doesn't mean they aren't still wired in parallel. Check the schematic.
    Step 1 of amp troubleshooting? A voltage chart at all tube pins.
  3. t-luxe
    t-luxe Tele-Afflicted
    so. cal
    Make sure your input jacks are wired and grounded correctly.
    Check the switching jacks for proper operation as well. Are you plugging the speaker into the speaker output jack and not the ext. speaker jack?
    Get out your chopstick and lightly tap the grid pins on the preamp tube sockets starting with V1A. You should get a healthy pop. If not, check the circuit associated with that grid.
    wmsimpson likes this.
  4. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Those 68k resistors should measure as ~34k because of the way the inputs are wired, there is nothing wrong there.
    Did you check your voltages? That's the first step to diagnosing.
  5. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    A big mistake I've seen in builds is the output jacks wired wrong, I seen the hot go to the ground lug.
    Output Jacks.png View attachment 637895
  6. RottenTheCat
    RottenTheCat Tele-Holic
    Drambuie, Africa
    Ext speaker jack is grounding. Even grounded, you will get a little output.
  7. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    Check and recheck the wiring to the volume controls. I got caught with that one once.
  8. ouaouaron
    Saint Louis
    thanks everyone I will try these suggestions
