Len058
I'm building the EF80 Bassman Micro by Rob and nearing the end I run into an issue. I have a 16ohm Celestion Greenback, which I want to use for it. Rob only specifies an 8ohm connection. The data sheet goes to 15ohm. I know a little about impedance so I think I can get away with connecting 16 ohm to the 15 Ohm tap. But which one do I choose.
Rob says 22,5K load. I can choose 24K but I think that would be too much because the load gets higher when connecting a higher impedance speaker. I think 21,5K @15ohm will get me in the ballpark with 16 ohm connected.
Should I do something special when connecting multiple taps? I have a feeling it needs ground somewhere when one is not connected
Advice please and thanks in advanced.
