Never thought I would hear a difference ...
Discussion in 'Glowing Bottle Tube Amp Forum' started by TheDams, Feb 21, 2020.
  1. TheDams
    TheDams Tele-Holic
    Minneapolis
    Today, I did some tube rolling in my EarFuzz 5W (based on a GA5): I swapped between rectifiers (5Y3), something I don't remember ever trying, because for me a rectifier is just here to convert/give juice to the amp :)
    I remember having a Bendix 6106 (almost never used it, bought it years ago when they were decently priced) somewhere in my NOS tubes stash.
    I swapped between the GE 5Y3GT that I had in the amp since a few months, and the Bendix.
    I swear I can hear a better/tighter bottom end, and it seems that the amp is a tiny bit louder, using the GE.
    I did the swap maybe 10 or 12 times to be sure I really heard a difference, and, for the life of me, I did !
    I would have never thought there would be a difference between rectifiers !
    What say you, oh tube amps gurus ?
    uriah1 likes this.
  2. schmee
    I say unless you rebiased to be exactly the same when you swapped, you dont know it was the tube. :>)
  3. TheDams
    TheDams Tele-Holic
    Minneapolis
    It's a single-ended (6sj7, 5881, 5y3)... so no bias (from what I know about SE amps ;) )
  4. MuddyWolf
    MuddyWolf Tele-Meister
    Paradise, Ca
    Naw I dont believe it. I've never tried myself but everybody on the internewt knows these fringe ideas are wrong.
  5. muchxs
    muchxs Doctor of Teleocity
    New England
    I say measure supply voltage.
  6. TheDams
    TheDams Tele-Holic
    Minneapolis
    I guess the slight difference in tone/volume comes from the fact - as I read somewhere - that a 6106 has a slightly different voltage drop than a “regular” 5Y3gt ?
  7. TheDams
    TheDams Tele-Holic
    Minneapolis
    I am not trained in tube amps electronics :oops: (even if I know my safety rules in a tube amp and some basic maintenance, and know enough in the use of a DMM).
    Where/how do I measure that ?
  8. muchxs
    New England
    Clip your black lead to the chassis. Using one hand measure voltage at Pin 8 of your 5Y3 (or 6106). Poke Pin 8 with the probe on your red lead.
    BobbyZ likes this.
  9. TheDams
    TheDams Tele-Holic
    Minneapolis
    Thanks muchxs... I will measure if I have an opportunity to open the chassis.
    for now, I’d say my post was more out of curiosity than anything else. I am just surprised to be able to actually hear a (slight) difference in low ends “tightness “/output.
    But as I said, I read somewhere that 6106 have slightly different characteristics than your standard 5y3.
    Correct me if I’m wrong.
  10. Nickfl
    Nickfl Tele-Afflicted
    All amps have bias, just because you don't have to adjust it when changing tubes doesn't mean that it isn't a thing or that it stays the same. Cathode biased amps are self-regulating (up to a point) but different tubes are almost certainly going to be at somewhat different bias levels due to changes in current draw and plate voltages, which is at least part of the difference people hear between different brands of power tubes.
    In this case, even though you only changed the rectifier I'm sure your voltages are different, possibly by a significant amount, and chances are that is what you're hearing.
  11. TheDams
    TheDams Tele-Holic
    Minneapolis
    Thanks for the explanation Nickfl ;)
    How fun, Bendix tubes (6106, or their 6v6 5992 ) are praised in a lot of places, but in that case, I actually prefer the much cheaper GE :D... price and fame are not always THE truth :rolleyes:
  12. robrob
    United States
    As muchxs said, using a different type rectifier can change the amp's operating voltage and voltage sag, both of which can affect the amp's tone, playing dynamics and loudness.
    SacDAve, muscmp and TheDams like this.
  13. gusfinley
    gusfinley Tele-Afflicted
    SLC, UT
    If you can hear the difference, then put the one you like the most in there!
    Don't let anyone tell you differently.
  14. TheDams
    TheDams Tele-Holic
    Minneapolis
    That is the first thing I did ;)
    Ascension likes this.
  15. slider313
    slider313 Tele-Afflicted
    NC
    The Bendix 6106 is an overbuilt 5Y3 and they take a good 45-50 seconds to warm up. They also don't produce the sag you would get from most other 5Y3's. The GE may be dropping more voltage and raising the current.
  16. Askwhy
    Askwhy Tele-Meister
    Utah
    The tech guys (though correct) are missing the simple fact that changing that tube, without rebiasing etc, absolutely does change the sound and feel of the amp. So what if making everything else the same would nullify or reduce the effect, the point is you don't HAVE to. If you hear a difference, there is one and and an easy one to get and change between those two specific tubes. Enjoy!
  17. FenderLover
    Minnesota
    That's a good point, but I'd suggest that maybe non-tech guys might come to think the difference is the 'sound' of a different rectifier, and less about of the changes it may have caused. For instance, some people stick a 12AU7 in the first preamp position and complain about how bad a 12AU7 sounds.
    robrob likes this.
  18. slider313
    NC
    The GA-5 is single ended.
  19. Commodore 64
    Commodore 64 Friend of Leo's
    Kent, OH
    Not saying you can't hear a difference at all. It's a bit of semantic argument. The rectifier tube is not in the signal circuitry. It's not affecting the signal. It can't.
    But...
    The operating points of every tube in that amp are set by a relationship with the plate voltage, cathode voltage, screen voltage. If that rectifier tube changed the B+ voltage, it changed every other voltage (and operating point) in that amp. So yeah, totally possible you hear a difference.
    BobbyZ and Askwhy like this.
  20. robrob
    United States
    The rectifier creates the signal base. A tube amp really is a modulated power supply so a change in rectifier output voltage directly affects the signal, especially the power tube output signal.
    koolaide likes this.
