Neil's Brotherhood 2021 build: The Starcaster project
Discussion in 'Tele Home Depot' started by RiversQC, Apr 18, 2021.
  1. RiversQC
    RiversQC Tele-Meister
    Quebec
    Okay, I can't wait any longer to jump in! The builds are all looking great and I'm feeling very inspired to build something, even if I have other projects in various states of completion... I like to "project hop" a little (a lot).
    I've been wanting to build a semi-hollow Starcaster for a while. And what better occasion that Brotherhood build 2021!
    It's a lot, huh? A semi-hollow but offset... the maple board... sometimes with TOM bridge but sometimes a fender style bridge... that headstock! Definitely a love-it-or-hate-it thing, and at first look I was a hard pass, but it has really grown on me. I've never played a vintage but a few various models over the years seemed cool.
    I'm not going to build anything truly faithful to the original but it will be Starcaster-like for sure. ;)
  2. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    I want one of these, but I want the tele headstock!!!
  3. RiversQC
    Quebec
    A major disclaimer is that I simply have to build this guitar on the cheap. For certain well-known reasons stores aren't really open even if I wanted them to be. So! I'm just going to use what's on hand, including some pine for the body.
    I don't know how many folks have built semi-hollows with pine, but I have some pretty clear boards and with the slightly larger body hopefully it won't be too light. So here goes!
    I printed off my drawings and used a bit less than half of this 2" x 8" x 8' board:
    Got er planed down to useable and glued up
    And the next day planed that all to size (which is a bit more than 1.75")
    There are a few very small knots but only on the top, which will be hogged out and covered. One knot is just glancing off to the side but I wanted to avoid it entirely, so for the record I am moving my centre line just a smidge off the glue line to accommodate.
    I also got a template ready for that job. Here's my start, then.
    crazydave911, mkster and secretsoundz like this.
  4. RiversQC
    Quebec
    I guess most (all?) Starcasters have shaped tops, but that's beyond me. This one will just be flat top and back, but I will add a belly carve to it.
    My plan of attack is to have the regular template shape (with a few pins so I can locate layers reliably)...
    And then use the cut out portion to add an inset that I can also locate on the back of the body later. So marking a cutting down this
    To this
    Then in that space I will route some terraces using this template that I cut for a strat project. I'll just re-use some of the curves, in this case going from my #4 depth through #1.
    Eh, it worked well enough for me to build this strat so hopefully I can do it again without incident!
    (Stock collage photos from last fall)
  5. RiversQC
    Quebec
    So I got to hogging out the body with the drill press, as one does:
    But I did call a couple of audibles as I went. (1) I left a little more wood for the jack than what the drawing showed, which is probably wise especially for pine. (2) I left some extra wood behind the bridge, partly out of concern for weight but also because I have this cheap Bigsby copy in my drawer that I maybe could use?
    I wanted to put in a poll or something... should I use this thing???? I'm going to screw something up or not be able to intonate, right? If you have ever had success with a Bigsby knock-off bought in a moment of weakness please let me know. It doesn't have felt on the bottom; arm moves well but I just don't know if I trust it. I'll think on it.
  6. RiversQC
    Quebec
    I'm going to try to see what I can come up with, but yeah, the tele headstock looks good on most anything. The Starcaster headstock? Well, you don't see that many places... but it's maybe part of the charm :lol:
    crazydave911 likes this.
  7. dreamingtele
    Id be interested to get a finished Starcaster body from you, if you can make a 25.5" telecaster neck work, and body routed for 2 P90's!!
    Please say yes!!!!
    drmordo and crazydave911 like this.
  8. wadeeinkauf
    wadeeinkauf Tele-Afflicted
    Monterey CA
    You did a great job on the strat. Looking to forward to seeing this one!
    crazydave911 and RiversQC like this.
  9. erix
    erix Tele-Meister Silver Supporter
    MI
    What a fun build idea! I’ve never used a bigsby (someday.....) but cheap or not, that big chunk of chrome on the body may draw the eye away from the headstock. ;)
  10. RiversQC
    Quebec
    I've been on a big P90 kick and... that would be super cool. :cool:
    I'm not a vendor member at TDPRI, so strictly building for fun. I suspect you could probably buy a boutique build for the shipping price from me to you anyway! But I'm glad to have you following along and would hook anybody up if I could :)
    Yeah, I never really use any sort of tremolo system, but the temptation really is the look of it.
    I'm thinking I'll leave the extra wood as a matter of weight/balance, and it gives me the option of adding what would be an aftermarket piece anyway. Hopefully I won't need the visual distraction but we'll see!
    Arch Stanton and crazydave911 like this.
  11. solfege
    solfege TDPRI Member
    Philly
    I'd use a JM trem rather than a bigsby. But then I'm one of those people who thinks that, properly set up, the JM trem is the best vibrato ever made.
    RiversQC likes this.
  12. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    Looks like a good and challenging build :).
    Good to see you in on the fun, and the best of Good Luck!
    Semi-hollows and Bigsbys are "in" this year :).
  13. Freeman Keller
    I'll just comment on the Bigsby question. I have no need for one but I will put one on a guitar if someone wants one. I'll also take one off if they don't. There is a thread right now at the Other Guitar subforum about removing one. If you are going to install it make sure its the right one for your bridge choice and that the angles are good.
  14. RiversQC
    Quebec
    You know, I've never actually played a JM with trem. Just about every guitar I've had has been a hardtail...
    Thanks! Yes, lots of nice thinlines being built this year. I've always been a metal head but once I started building I've really enjoyed making semi-hollows and thinlines. Go figure! Glad they're in. :)
    old wrench and crazydave911 like this.
  15. RiversQC
    Quebec
    Thanks, Freeman, as always. I'm going to take it slightly easy on myself and build this with a vintage-style tele bridge, no angle. If I did add the Bigsby, I could dremel/file off the gaps for it in the back plate.
  16. Yonatan
    Yonatan Tele-Meister
    Israel
    Impressive start!
    Did I miss it, what will you use for the top?
  17. RiversQC
    Quebec
    Great question! Here it is:
    More on that...
    billder, crazydave911 and Yonatan like this.
  18. crazydave911
    East Tennessee
    I'm planning sorta similar for next year's BB. I'm planning on what I've done before. A thin ply top and back and 2 X 4s for the sides and internals. Last one I dyed and did a burst. But now there is so much reasonably priced gorgeous ply and veneer it's crazy :cool:.
    By the way I'm not sure I blame that headstock entirely on Fender. During the lawsuit era Ibanez made a one piece maple neck a dead ringer for a Tele except for, you guessed it, that headstock :lol:. Having had said Ibanez I always wondered if that headstock was part of settlement lol
  19. RiversQC
    Quebec
    So like I said, my options are a bit limited on this build. I blew my monthly budget on buying a 20" aluminum sanding block for fretboards from Philadelphia Luthiers, which arrived today! So that was cool but now I'm scrounging. :lol:
    I have some maple and other potential tops in my stash but none quite right for this build, since I'm planning to paint the top.
    So about a month ago I had my boys at the community centre skatepark and they were throwing out some pallets, and there was this nice clean piece of 4S maple, 3/4" thick, 3 1/2" wide. It had a bit of a bend so no good for necks... but clearly too nice to throw out. Yoink.
    I feel the need to apologize for such a low-end build, but necessity yadda yadda. And I love building with all kinds of wood but I really enjoy a bit of salvage. :rolleyes:
    So I was thinking that my bandsaw could handle a 3 1/2" re-saw, and if I cut it exactly in half I could get some lengths of 1/4" for a top?
    That was yesterday, and today on and off between zoom meetings I glued the panels up. I had to borrow a little bit (still to be glued) to make it all work but it'll go.
    Thickness is under the recommended 1/4", but over 3/16". It's a hair over 5mm, 0.200". I'm going to need an American to tell me that fraction, lol. The risk as such is inviting feedback but I guess this'll be a test of sorts. (This did play a bit of a role in me deciding to make the overall cavity slightly smaller, maybe to combat that).
  20. Willie Johnson
    Willie Johnson Tele-Holic
    Chicagoland
    Very cool idea. I have the Squier CV Starcaster in sunburst, but kinda wish they had the natural finish--those look the best.
    If you don't do the giant gross sex machine headstock, at least do a '70's Strat one instead--that would look ace.
