Need to clean the darn snow off the roof!
Discussion in 'Bad Dog Cafe' started by BobbyZ, Jan 23, 2020.
  1. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Haven't been really worried about the snow on the roof of the Avion this winter. I cleaned a couple of feet of the crap off the old house so it doesn't fall in before I tear it down. My water comes from the house, washer a dryer is in there, plus storage.
    The camper I was thinking about doing this weekend. There's enough heat loss through the roof to melt it and I thought maybe that melted snow could cause an issue. . . .
    This morning I went to open the door and couldn't, freaking ice on the step. Didn't want to force it and bend the door. OK there's an emergency exit window, I'll just crawl out through that and chip ice. Well that didn't work, more damned ice! But I could get under that with a screwdriver and chip it. Then jump into about two feet of snow and made my way round front and chipped that ice.
    Yeah 20191231_124518.jpg I'll be cleaning the roof today!
    Texicaster and Torren61 like this.
  2. beninma
    beninma Friend of Leo's
    Massachusetts
    Would Heat Tape work? Do you have power out to that camper?
  3. Dreadnut
    Dreadnut Tele-Meister
    Grand Rapids, Michigan
    Here's my advice, from an RV owner in Michigan: Leave it alone. You're likely to cause more problems than you'll solve. If it ain't broke, don't try to fix it.
    Torren61 likes this.
  4. boris bubbanov
    New Orleans, LA + in the
    Won't he have to stay in there, all winter?
    Talk about Cabin Fever.
    Torren61 and Toto'sDad like this.
  5. televillian
    televillian Tele-Holic
    Clarkdale, AZ
    whatever you do don`t move to Arizona
    Georox and Torren61 like this.
  6. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Bakersfield
    Bobby, you are either the toughest man in the continental USA or the craziest! Wouldn't it be easier to just get a flail and beat yourself with it?:lol::lol::lol:
  7. Toto'sDad
    Bakersfield
    I'm thinking BobbyZ is going to write a book called, "Revenant part deux." :D
    Chunkocaster, BobbyZ and Torren61 like this.
  8. Toto'sDad
    Bakersfield
    Might be for the best!
  9. Chunkocaster
    In space with Ziggy
    Couple more days and you'll have yourself an igloo.
    Igloos are meant to be warm inside aren't they?:confused:
    Toto'sDad and Torren61 like this.
  10. rand z
    rand z Friend of Leo's
    trumansburg, ny
    Hey!
    DJ Chris supposedly lived in an Airstream in Cicely, Alaska (Northern Exposure).
    I lived in a travel trailer from December through March in the Endless Mountains of Northern PA, just a few years ago.
    Even used an outhouse for the whole duration.
    It was cold but a unique experience.
    And, I looked at it as a challenge.
    In fact, it was really beautiful with the mountains, frozen streams and snow!
  11. dkmw
    dkmw Friend of Leo's
    Florida USA
    The answer is clear.
    Flamethrower.
  12. Straydogger
    Straydogger Tele-Holic
    Western Pa.
    This is 4 years ago today here in Western Pa. Today it's 40 degrees. I like today better. :)
    Toto'sDad, BobbyZ and Torren61 like this.
  13. Big_Bend
    Big_Bend Poster Extraordinaire
    Houston, TX
    I would go bat-**** crazy if I was snowed in for months in a little metal tube and couldn't get out.
    Do what you gota do to survive, and have an escape route.
    Hell I'd go crazy just living in that area, even if I had a well insulated house that someone else maintained.
    Good luck, be safe!
    39martind18, BobbyZ and Torren61 like this.
  14. Slap Axe
    Slap Axe Tele-Meister
    Rocky Mountain Way
    Looking pretty buried up there man! I used to have to remove snow from the fiberglass top of my VW camper when it got too deep. I wasn’t living in it, but didn’t want to see it crater sitting in the driveway.
    I’m sure you’re all over it, but a ladder and a big shop broom works pretty well. Sometimes I’d turn my driveway snow shovel upside down and carefully push it off the other side. Good luck!
    BobbyZ likes this.
  15. Dreadnut
    If it isn't leaking, leave it alone.
  16. Toto'sDad
    Bakersfield
    The whole thing would probably go up in smoke in twenty seconds in your neighborhood. :lol:
    Chunkocaster likes this.
  17. Jupiter
    Osaka, Japan
    we haven't had a lick of snow yet
    I'm starting to actually worry
  18. Chunkocaster
    In space with Ziggy
    We have another 40c day coming up next week. I could make a small fortune off that mobile igloo.
    BobbyZ and Toto'sDad like this.
  19. BobbyZ
    Snellman MN
    I used a shop broom to clear the loose snow off and saw the issue. No matter how much insulation you put in a roof there's always some heat that melts the snow right on the roof's surface. That's why houses have a space between the roof and insulation that's vented.
    An Avion is spray foamed and probably still is one of the best insulated campers ever built. But the walls are only somewhere under two inches thick. So that melting, especially with all the snow up top was pretty bad. The resulting water froze on the sides known as an "ice damm".
    From now on I'll be sweeping the roof clean after every snow fall!
  20. BobbyZ
    Snellman MN
    You can't see the ice around the edges in this shot but the snow melt is pretty obvious. If it hadn't melted it be well over two feet deep now! It was a good foot thick out on the edges.
    Supposed to be pretty warm for awhile with highs in the upper 20s. Maybe with some sunshine it'll loosen the bond between the aluminum and I can carefully get most of it off. 20200123_165553.jpg
