Need some help with Princeton Reverb Build
Discussion in 'Amp Tech Center' started by KBarW, Feb 24, 2020.
  1. KBarW
    KBarW Tele-Meister
    New Braunfels, Texas
    Building a Mojotone Princeton Reverb amp. All the way down to the testing. I've run into a big problem - I'm reading 833 volts at the power tubes. The rectifier is reading 328 volts just like it should. The diode board is correct with the proper polarity.
    I've looked over my wiring on the transformer section and everything looks good.
    I checked the eyelet board with the power tubes removed and every point I checked was reading about double what it should be.
    I'm experienced in soldering, having built tons of connectors, cables, rack panels, etc., but I'm a total novice at amp building.
    Anything of the top of anyone's head that I could check?
  2. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    Did you switch your meter to DC Volts to measure at the power tubes?
    Nickfl likes this.
  3. corliss1
    Lansing, MI
    Alright, so move up from the rectifier. Check the AC coming into it from the power transformer. If that seems reasonable then check the DC at the first filter cap node, which will also be connected to the rectifier. If those two areas aren't right, nothing else will be right.
    Move out from there - second filter cap node, and so on.
  4. BigDaddy23
    BigDaddy23 Tele-Holic
    Step one
    Phrygian77 likes this.
  5. KBarW
    KBarW Tele-Meister
    No, I didn't. The layout diagram just says 380v. Do I assume that every voltage is DC unless it specifically says AC?
  6. KBarW
    KBarW Tele-Meister
    Thanks for that.....now if I only knew what you mean by filter cap node. The voltage from the transformer measures properly at the rectifier.
    It's embarrassing at my age and experience in PA systems and playing to be such a newb at this.
  7. corliss1
    Lansing, MI
    Filter cap nodes are usually lettered on some schematics, with A being the very first cap that connects to the rectifier.
    So ignore the "node" thing - what's the DC volts at the first filter cap connected to the rectifier tube?
  8. dan40
    dan40 Friend of Leo's
    Richmond Va
    The voltage from the PT to the rectifier will be AC. Everything after the rectifier will be DC. The 6.3v secondary for the tube's heaters will be an AC voltage at every socket. Be aware that voltages will be high until you get power tubes installed.
  9. Phrygian77
    Crawfordville, FL
    833?? No mater what your VOM is set for, that seems odd. My PR builds have been around 414-422VDC with a 630VAC secondary.
    LudwigvonBirk likes this.
  10. Whatizitman
    Whatizitman Poster Extraordinaire
    WV
    No. You need to know what currents are AC or DC in an amp, and why. A schematic assumes this is fundamental and known.
    The rectifier changes AC to DC for the tube power supply. The big caps further ‘smooth’ the DC. Power coming to the tube plates will be DC. The signal circuit will be AC. Sound is an alternate current form (AC). Heater supplies can be AC or DC, depending on the amp.
  11. LudwigvonBirk
    LudwigvonBirk Tele-Holic
    Madison
    Mojotone’s wiring diagram now lists desired-voltages at a bunch of different test points. See here: https://system.na3.netsuite.com/core/media/media.nl?id=3393932&c=923962&h=1a2d186b30f62b14658d&_xt=.pdf&vid=sfseFGyuAlFmiGXM&chrole=17&ck=WMT1fWKMAqfLk70t&cktime=175724&promocode=&promocodeaction=overwrite&sj=wQoirDS18J968UFOTH2GgswYo;1582603724;406816000&gc=clear
    What are yours at all those same test points? If you can post a pic of the above image with your voltage measurements overlaid, that would be super helpful. (Mojotone doesn’t show desired voltages on their PR schematic, idk why).
    Also, what kind of meter do you have and what is it set to?
    You will totally love this amp when you are done. Lots of us here have built and fixed these.
    trber likes this.
  12. Lowerleftcoast
    california
    Everyone starts somewhere. The people here will be helpful. It may be a little overwhelming having several people asking many questions but you should be able to get your questions answered. Hang on, you will learn a lot.
    I hope the readings you get with your meter on DC make sense. This is not always the case though because some meters have difficulty reading high voltages. Your reading of 833 Volts is most likely inaccurate and just the meter having trouble recognizing a DC voltage on the AC range.
    Post your voltages. I will be interested in your findings.
    trber likes this.
  13. trber
    trber Tele-Meister
    NorCal
    Yes, check the mojotone diagram as it has labeled voltages, AC and DC. I concur... this amp is a hoot when you get things sorted. I just went through a bunch of troubleshooting problems in December. It'll come together and you will be psyched when it does!
    I just got done playing mine for the last hour or so. So great.
    Sent from my SM-G955U using Tapatalk
  14. koolaide
    koolaide Tele-Afflicted
    south carolina
    I would recommend that you see YouTube (Uncle Doug Chanel) How tube amps work- Part 1 and 2 first. Then review his content as needed. The first two videos will help you understand AC vs DC and what is where in thee amp, and give you a basic understanding. Great foundational stuff. Short and not too boring.
    Good luck with your project.
    Pick_n_Strum and tubedood like this.
  15. KBarW
    KBarW Tele-Meister
    That's the layout diagram I'm using. Unfortunately, I was taking readings in AC throughout. Now I know that only those that say AC are indeed AC. I'm about to start over with my testing and checking voltage in DC at the appropriate points.
    I'm trying to understand the meaning of B+ and secondary voltages. Wish I was more educated in this, but I guess I just assumed I could follow the instructions and it would be fine. I'm very meticulous in everything I build....or at least try to be.
    I'll go start the process over with the appropriate setting and see what happens....
    Oh, I do have one question.....when I was testing voltages (incorrectly) with the power tubes removed, after a while the fuse blew. Would this be typical with the power tubes out?
    Thanks to all of you for the suggestions...
  16. KBarW
    KBarW Tele-Meister
    Wow....just watched both videos.....really clears up a lot. At least I now know what the heck a "heater wire" actually does.... I'm going to do a little more testing now that my understanding is clearer.
    Thanks
    trber likes this.
  17. KBarW
    KBarW Tele-Meister
    This is the cab I built for it.....waiting patiently.
  18. trber
    trber Tele-Meister
    NorCal
    Nice! 10 or 12 inch?
  19. KBarW
    KBarW Tele-Meister
    12" Putting a Cannabis Rex in it. Or, I'll put that in my Boogie and move the Lil' Texas Neo into the Princeton.....I'm looking for the Princeton to marry up with the Tele for clean country. The Boogie gets a LP for my Rock and Blues Band.
    trber likes this.
  20. Lowerleftcoast
    california
    No.
    1 You may have touched something in your testing.
    2 You may have something wired wrong.
    3 Without the tubes installed, the voltages can exceed the filter cap voltage ratings causing them to fail.
    I would suggest building a "light bulb limiter" to help with amp testing. How to video is available on you tube. It is a handy tool for ailing amps and startup of new builds.
    trber and koolaide like this.
