Actually, wait, now that I think more about it, I guess that wouldn't work right? as both neck and bridge pups would go to just one lug on the 5 way switch. Doesn't help that I don't know how exactly a typical 5 way switch works. Think I have more reading to do.
Yeah, that's what someone else said to me too, about using a stacked, concentric pot. problem is, I wouldn't have enough clearance to get it through the f hole and into place. It's a tight squeezeCorrect. Doing it that way doesn't give you a way to split up those two pickups.
What about one of those stacked potentiometers? I've never used one but it would be like two pots in one then you could have neck tone and bridge tone separated on that tone pot, but you'd still have three volume knobs.
Thanks man. Just one question: The solid blue and green lines (hot wires) going from the neck and bridge pups to the selector switch, you then have them continuing on as dashed lines, coming out of the lugs on the switch they went into. Is that right?
ah, ok, I get you. that's great, thanks. It does make sense when you explain it that way
Looking at the two tone pots for neck and bridge. They're wired slightly differently. I presume that's intended?
I just want to be sure of everything before I start soldering.
sounds kind of similar to my journey with guitar wiring and electronics in general.Here's a thread of mine from a few years back asking the same question. Post number 5 answers it.
Help me Understand - Strat Wiring Question
One of my recent goals has been to understand the how and whys of guitar wiring. I have no background in electricity so it's taken me awhile. I've gotten fairly good at wiring my guitars the last few years. And now I really enjoy it. The last one I wired up, i was actually able to diagnose my...www.tdpri.com
You didn't ask...but a little background on me. I built my first guitar in 2015 and had to have a friend wire it for me because everything I had done up to that point with a soldering iron was usually a two steps forward three steps back kind of thing.
After that I started trying to wire my own guitars with diagrams I found online and did okay, but wanted to understand what was going on, not just follow a map.
A year or so ago I had progressed to the point where I could take concepts from two or three different diagrams and blend them together (sometimes with help from the good folks here). And then suddenly it all kind of clicked to where I (am definitely still learning) but can take the concepts and throw them together on my own.
Point of all my rambling is I've come a long way in just a few years. And I find guitar wiring to be so exciting and fun to dig into. It's my favorite part of new builds now. So even if some of it looks like gibberish now, you're never too old to figure it out.
