This post is directly related to this one:
www.tdpri.com
I'm using an import style 5 way blade switch, due to the standard 5 way switch being too tall to fit in through the f hole and I've never wired an import 5 way switch before.
So anyway, I'm going to have 2 vol pots, 2 tone pots, 1 two way (ON-ON) mini toggle switch, 1 three way (ON-OFF-ON) mini toggle switch.
I'm going to have 3 pickups: neck, middle, bridge.
1 vol control will control both the neck and bridge pups.
Other vol control will control the middle pup.
1 tone control for the neck pup.
Other tone control for the bridge pup.
I hope to use the 3 way (ON-OFF-ON) toggle switch to give three tonal option for the middle pup:
- simulate tone at ten
- bypass the cap (brightest sound)
- simulate tone roughly half way down
I'll use the 2 way (ON-ON) switch as a phase reverse switch for the middle pup, so I can get out of phase sounds in both positions 2 & 4. I've wired switches for phase reverse before, so this bit is not new to me.
I guess the main areas I'm not sure about are how to wire the 5 way import style blade switch to the appropriate pots and also the right way to incorporate the 3 way toggle switch for middle pup tone.
Is it possible to change a pickups' tone via a 3 way mini toggle switch and no tone pot? (or some other way with no tone pot)
I am in the middle of a new guitar build (see: https://www.tdpri.com/threads/new-build-thinking-of-two-humbuckers-and-single-coil-in-middle-position-opinions.1104191/) Regarding that thread, I went with the Guitar Fetish over wound tele neck pup for my middle position pup. Anyway, the pickup...
