Need ideas to incline a cab.
Discussion in 'Amp Central Station' started by TubeBlues, Jun 21, 2021.
  1. TubeBlues
    TubeBlues Tele-Meister
    Quebec
    I have this small 1x12 Fender SuperChamp X2 cab that I need to incline.
    The cab is in my living room and I don't want to use an amplifier stand, as they don't look nice.
    Anyone has ideas on how I could do it?
  2. uriah1
    Around
  3. stormsedge
    stormsedge Friend of Leo's
    E. Tennessee, USA
    Cut a couple of wedges from a piece of lumber the height you want and stain them, then lean the top against the wall and put the wedges under the bottom. I did that until I bought amp stands.
    Or a foam wedge.
    Mowgli, W.L.Weller and nojazzhere like this.
  4. The Ballzz
    The Ballzz Tele-Afflicted
    Las Vegas, NV
    Break out your wood working skills (or a friend's) and build a stand from wood that matches/compliments your living room furniture and/or decor. There are multiple plans out there, some adjustable, some fixed. Take your pick:
    wooden amplifier stand
    I personally like this on, all you need is to choose your angle:
    Just Sayin,
    Gene
    old wrench and stevemc like this.
  5. nojazzhere
    nojazzhere Doctor of Teleocity Ad Free Member
    Foat Wuth, Texas
    How much "incline" do you want? I have used a piece of 2"X2" wood, cut to the width of the amp, and painted black. Tip amp back, place this under front edge, and it gives you a slight tilt. Not really noticeable, but solves the problem. (if that's enough "incline" for you)
  6. Mjea80
    Mjea80 Tele-Meister
    Ontario
    The premade ones everyone is suggesting look good and will do exactly what you want.
    But, is this just for home use?
    If so use anything really.
    I use an empty plastic harmonica case. Does the trick. :)
  7. David Barnett
    David Barnett Doctor of Teleocity Ad Free Member
    Stick a couple of door stops under it.
    Mowgli, DADGAD and codamedia like this.
  8. televillian
    televillian Tele-Afflicted
    Clarkdale, AZ
    lean it against the wall
    Blackmore Fan likes this.
  9. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Make a little kickstand for it from 1/4" Masonite. A paint stir stick will work too.
    Stillhouse and Willie Johnson like this.
  10. randym
    randym Tele-Meister
    Pewaukee, WI
    I've used door stops, and hockey pucks, and 2x2/2x4 under the front feet.
    Mowgli and stormsedge like this.
  11. zeppelinofled69
    zeppelinofled69 Tele-Meister
    Buffalo, NY
    How about adding another speaker cab... Mini-stack for the win
  12. Willie Johnson
    Willie Johnson Tele-Afflicted
    Chicagoland
    Also makes a good leprechaun trap around St Patrick's Day.
    You can also get chrome Fender tilt-back legs; they sell them aftermarket. Enjoy your SCX2; great little amps, especially with a speaker swap and biased to spec.
    Stillhouse and Coffeemutt like this.
  13. codamedia
    Western Canada
    Door wedge. The further back it is placed the more angle you have.
    Mowgli likes this.
  14. nutball73
    nutball73 TDPRI Member
    I just stick a book under the front edge of mine. Change the book depending on the mood, or if someone's visiting put something esoteric under there.
    El Marin, Boreas and stormsedge like this.
  15. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I stuck some Fender legs on my Princeton. Works great. Not sure if your box is big enough.
    I used a book before that - Stephen King's Danse Macabre.
    telepraise likes this.
  16. 39martind18
    39martind18 Friend of Leo's
    Spring TX
    If the cab is open backed, one of these not only gives the tilt angle, but the "bass reflex" enhances the sound- makes my SCXD sound huge.
    Mowgli and DADGAD like this.
  17. DADGAD
    DADGAD Friend of Leo's
    SoCal
    Looks great! I googled "enhancer mini" but got no results. Do you have a link for that?
    TNX
  18. randym
    randym Tele-Meister
    Pewaukee, WI
    Oh, and Amp Wedge.
    green_henry likes this.
  19. Obsessed
    Obsessed Telefied Silver Supporter
    Montana
    Atlas make some awesome looking stands that fold up, made from wood like cherry and walnut and even make this additional stand for a head. Of course these cost more than my amps, but for tasty home stands for spendy amps … 0FF7DAA6-7886-41C7-B56C-C505D4FC345A.jpeg
    redchapterjubilee, JL_LI and rojo412 like this.
  20. Axis29
    Axis29 Poster Extraordinaire Silver Supporter
    Beaumont, CA
    I'm trying to find pictures of my old amp stand... But., can't seem to find any.
    Anyway, it was basically two l-shaped pieces connected on the upright by some hinges. The two 'feet' of the L, slip under the amp and hold it at whatever angle you set. It worked great for me for gigs back in the day when I was using a Deluxe Reverb. Worked well at home as well for practice and general noodling.
