Need help with reverb tank codes
radiocaster
europe
So build your own better version. It's essentially just a bunch of op amps with a monolithic IC for the output. That 'distortion' circuit looks basically like a Tuber Screamer.
It's got this crazy metal sound, not my video but it sounds like this.
I wouldn't use the reverb tank for this, but it would be cool to play other stuff on it as well.
Phrygian77
Gold Supporter
Crawfordville, FL
I had just briefly looked at the schematic. While it's not exactly a Tube Screamer, it's still a typical arrangement of clipping diodes/LEDs in an op-amp feedback loop.
radiocaster
europe
But anyway, getting back to my question, the tank being an 1BB2E4A, the E means "No Outer Channel":
https://www.amplifiedparts.com/tech-articles/accutronics-products-and-specifications
Does this mean this specification is irrelevant, and I can use any of the ground/isolation options on the tank?
The locking device option is clearly irrelevant, not even sure what a 4 type is, or how you would lock a tank in a closed back cab with no special device. Nor are any versions other than 1 easily accessible on the market.
MatchlessMan
Wiltshire UK
My experience of current production tanks from the likes of MOD is that the decays are much longer than would be expected from a given digit code. I suggest go for a 2 at most - I found 3 pretty much unusable except for massive lingering ambience.
Bill Moore
Silver City, New Mexico
Radiocaster, where did you find the pot? I have a 15G chassis that I was contemplating filling in the reverb circuit, but didn't find the correct control pot.
radiocaster
europe
Haven't started it yet. In fact I haven't even bought the other parts, but I'm sure I have some resistors and maybe some caps and an IC socket as well.
It's a pc board mounted pot, right? I may have one of those as well. Or I can get those locally, I just can't buy the ones with eyelet solder lugs offline.
Bill Moore
R58 on the schematic, 50KB snap in #034719.
I checked CE, and a few other sources, and don't find that value.
Edit, just checked by part number, several sources show availability!
