need help with does ranger transmission problem
Discussion in 'Bad Dog Cafe' started by timA68, May 24, 2020.
  1. timA68
    timA68 NEW MEMBER!
    Grand prairie tx
    I bought a 2001 ford ranger edge previous owner had new clutch and all put in . he was driving with no problems . stopped at red light and it refused to go intoany gear I've looked at it and with truck on or off shifter does not move help if you can . would like to know what needs to be fixed on it thanks
  2. willie
    willie TDPRI Member
    Dixie
    Possible clutch linkage adjustment....
  3. dented
    dented Doctor of Teleocity Gold Supporter
    I-10 East onramp
    Linkage at the tranny. Need someone under the truck to follow what isn't moving. Oh and Welcome to TDPRI! Thanks for stopping in and I hope you get your problem solved.
  4. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    No external shift linkage . Linkage issues are under the transmission top cover . Hopefully , there is a removable access panel in the floor . Push clutch pedal to floor and check if rear wheels will turn . If they don't , release the parking brake ( bad humor attempt ) . With the parking brake released , and the clutch pedal depressed , the real wheels should turn . If they do not , there is a good chance that you are in two gears at the same time . This indicates a linkage issue . Good luck .
  5. timA68
    timA68 NEW MEMBER!
    Grand prairie tx
    thanks for all yalls help I'll give update on what it 2as when I get it fixed . at least now I have an idea of what to look at
