Missing Link
Hi folks first a little back ground on this, I believe its a 1982 Sunn Beta Lead Digital C-Mos solid state 100W combo guitar amp.
I bought this amp a weeks ago after giving it a hard test with my guitar for at least 30 minutes without any troubles, and while talking over price with the seller and some of its history/small talk it was left on for at least 45 minutes and still without any troubles. The garage had some florescent lights in the area so it had what I presumed was some interference, hum.
After loading the amp in my truck face up, it was unloaded and set on the flood f my garage without any bumps or bangs.
I set all the knobs on the face of the amp to zero to include the vol knob and plugged the amp in and checked the jumper cable for the head to speakers to make sure it was not damaged in transport. Without an instrument plugged in I went to turn the power on and as soon as I did we got this extremely loud buzz sound like a bad ground but loud. I turned it off as fast as possible to save what I could just in case it was to blow up. So we checked all the wiring from the cab and anything else that was obvious that may be the cause. Turned it on and the same, very loud hum, buzz. I called the gent I just bought it from and explained the situation gong on with the amp. He never had a problem with the loud hum when turned on, but he did offer to take it back if I wanted. While on the phone with him I wanted to let him hear the sound, and yep you got it it was gone, no noise, no loud buzzing, nothing.
Fast forward to today - I had the head out of the cab to clean this 41 year old amp which when is played plays very nice but with that semi loud hiss in the reverb controls when at 9:00 and up. I wanted to check the reverb tank and its wire shielding to see if it was the cause of the extreme loud hum that have not happened since I go it home. The springs still have some tightness and not sloppy so I put it back in cleaned and installed the head back into the cab, plugged it in and yep externally loud hum so I turn it off as fast as possible.
I apologize for the long winded description but when asking folks on what maybe a problem I found it best to describe it as best as possible, sorry.
Anyway I love the amp and would like to keep it, but I unfortunately do not have a amp tec or service in my area (40 miles away) so I wanted to ask if from what you folks have read what would you suggest to check or take a closer look at.
I keep thinking that when I transported the amp on its back maybe the reverb tanks was bumped or messed up someway, and also when I removed it today to clean/check on it, it did the same thing as before. I am baffled that it seems when maybe 30 minuets goes by it is fine as it is now, no loud buzz or hum, sounds fine, plays fine. I also left the power on for two hours to see it its a heat related problem but it turns off and back on without a problem and no heat felt anywere on the head??
Would a Reverb spring tank cause this??? Any constructive information and questions are more than welcome.
Thanks
Thanks
