Need Help Replacing My Amp; Which One?
Discussion in 'Amp Central Station' started by Mimirr, Jul 15, 2020.
  1. Mimirr
    Mimirr TDPRI Member
    United States
    I'm currently unhappy with my amp. I've only owned it for about 8 months, but I didn't really gel with it. I've been trying to look online for a replacement, but I feel lost in a sea of amps. Hopefully, you guys can help me narrow in on a few amps. Here's some info to help you.
    • Current amp is an EVH 5150 III 50 watt head. Great for humbuckers, but Tele's with single coils sound like crap on distortion channels. Also, a bit too high gain for the majority of what I play. Is nice to play metal every now and then, but not necessary.
    • Need an amp that will sound good with single coils and humbuckers on both clean and dirty channels.
    • Must be 50 watts. No more, no less.
    • Style of musical ground it should cover - AC/DC, Van Halen, Guns N' Roses, Stone Temple Pilots, Rage Against the Machine.
    • Have an effects loop.
    • 2 Channels, clean and dirty, footswitchable.
    I'm disabled so it makes it hard to get out and try amps. Plus, with the added virus going around, it's even more difficult. Hopefully, you guys can help me out. I'm having a hard time finding the right amp for me by doing Google searches.
    Thanks in advance!
  2. Whatizitman
    Whatizitman Friend of Leo's
    WV
    With the exception of STP and later EVH, those are all Marshall tones.
    EDIT: Also, you didn’t specify cab or speakers you are playing through.
    Sadly, Marshall no longer makes a 50 watt DSL head. But the 100watt head has power scaling. OTOH, I’m of the thinking to avoid 100watts as it costs more for retubing. That’s just me. In any case, there is not a lot of volume difference between 50 and 100watts.
    Older 50 watt DSL? If you want new there are other options. Fender bassbreaker is Marshall-y. Supersonic less so, but is high gain. Blackstar and Jet City could work. I’m not sure if they all have 50 watt options, but a google search can confirm. All have two channel options.
    There are also tons of Marshall clone makers with Plexi and JCM800 variants with 50 watt and two channel options (I assume), like Friedman, Metroupolis, Ceriatone, Germino, just to name a few.
    Mimirr likes this.
  3. Mimirr
    Mimirr TDPRI Member
    United States
    Playing through a custom Zilla 1x12 cab that's oversized to the point of almost the size of a 2x12. Celestion Vintage 30 is in it at 8 ohms.
  4. branbolio
    branbolio Tele-Meister
    hawaii
    What’s your price range?
  5. Mimirr
    Mimirr TDPRI Member
    United States
    Somewhere around $1,500 new or used.
  6. Dismalhead
    Antelope, California
    Marshall or Blackstar, unless you have a lot of cash for a Mesa.
    Tim S, Jakedog and Javier668 like this.
  7. Mimirr
    Mimirr TDPRI Member
    United States
    My daughter has a Blackstar. I was under the impression that they were budget grade amps.
    The highest I could do is probably $2,000 new or used.
  8. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Look for a Mesa 25 watt anything. They're power switchable and very tweakable with good eqs and nice fat transformers. I had a Mini Rectifier clone. Great amp
    Dismalhead likes this.
  9. Whatizitman
    WV
    Mimirr, tele12 and brookdalebill like this.
  10. hotairguitar
    hotairguitar Tele-Meister
    Reading
    I need this thread, combo options please?
  11. Whatizitman
    WV
    OP asked for heads. Start a new thread.
    Dismalhead, Mimirr, Wally and 2 others like this.
  12. nicknklv
    nicknklv Tele-Meister
    Stockholm, Sweden
    I'd recommend the Victory Sheriff series. 45w head, Marshall style, fantastic build quality, power attenuation (30/6w), what's not to like? :)
    P.S. Did I mention it's handbuilt?
    https://www.victoryamps.com/sheriff-44
    Dismalhead and Mimirr like this.
  13. dogmeat
    dogmeat Friend of Leo's
    Alaska
    maybe you've been there already but there are tons of pedals that make a clean channel sing. for fat cleans, I like the Klon clones a lot... Archer, Tumnus etc. and a bit different circuit that does a lot of things from Dumble to ??, The Dude... wow.
  14. eddiewagner
    eddiewagner Poster Extraordinaire
    ROCK!linghausen/germany
    Tonemaster Twin and two drive pedals
  15. VintageSG
    Yorkshire
    Laney IRT60H
    Ignore the upper 10 Watts, or just use the VariWatt control to knock them down a little. What's a few extra Watts anyway.
    Pristine cleans through all manner of crunch up to and including all manner of modern detuned riffery. Independent EQ, FX loop, reverb.
    https://www.laney.co.uk/products/ironheart-irt60h-tube-head
    Mimirr likes this.
  16. radiocaster
    europe
    Lots of options: Marshall, Mesa, Soldano, Orange, even that new VHT Dumble clone might be good.
    Heavy distortion is often not that good with single coils, except on a few amps. The best you can do is listen to youtube demos. Still won't be perfect because the cab is 50% of the sound in my opinion, plus they play differently than you, but it's the best in this situation.
    Mimirr likes this.
  17. Bluey
    Bluey Tele-Meister
    Try the Marshall SV20 plexi. Yeh I know its only 20w but it's only a couple of db difference through the same cab. Plus in reality they are prob. closer to 30w. line out & FX loop.
  18. Dismalhead
    That sounded great, now I'm wanting one. Great guitarist doing the demo too.
  19. Mimirr
    Mimirr TDPRI Member
    United States
    I've already been down the pedal route about 15 years ago with a Carr Rambler 2x10 combo. Amazing amp, but didn't fit my playing style. I got it for a certain gig that played that kind of music. I'm an amp distortion guy.
    dogmeat likes this.
  20. rangercaster
    Knoxville TN for now
    I think a 100 watt Marshall may work ...
    Order online from a company with a good return policy ...
    30 days should be adequate...
    45 is great ...
