Need help repairing a DOD 690 chorus
Discussion in 'The Stomp Box' started by Salty_critters, Apr 3, 2020.
  1. Salty_critters
    Salty_critters TDPRI Member
    Virginia
    Hey all, I'm hoping someone on here has some insight into this big-box chorus pedal. It's a DOD 690 Chorus, made in the late seventies I believe. I love the sound of it but it has started making unpleasant distorting noises, almost like a solid-state amp clipping but much harsher. I know next to nothing about solid state circuits or pedals so I'm not sure where to start! I also cannot locate a schematic for this pedal on the net. Any ideas what I should look into replacing?
  2. Lowerleftcoast
    Lowerleftcoast Tele-Holic
    california
    Try "chop sticking". Poking at parts and solder joints with a non-conducting chop-stick type device. You are looking for poor solder joints or noisy parts.
    Clean the jacks and pots. The jacks are probably switched. Those switches should get cleaned.
    Aluminum electrolytic capacitors can cause problems when they get old. They are the ones that look like little cans. They are old.
    If any of the parts are in a socket, those contact points should be cleaned as well.
    rangercaster likes this.
  3. Salty_critters
    Virginia
    I guess I should mention, the crackling distortion only happens when a signal is passed through the pedal. At idle it's as quiet as it should be.
    The electrolytics are probably due for replacement, you're right. I'll give all contacts and pots a good scrub, I didnt see any cold joints.
