Need help figuring out polarity
Discussion in 'Burnt Fingers DIY Effects' started by gitlvr, Feb 25, 2021.
  1. gitlvr
    gitlvr Friend of Leo's
    Northern Va.
    Hi, I am currently powering my pedals with a Boss PSM-5 Power Supply and Master Switch. It works well, but takes up a pedal space on my board.
    I want to replace it with this.
    It is a 1 Spot I got from my brother. He modified it to run two pedals without a daisy chain.
    The Boss power supply I'm using has the plug that you normally plug into a pedal, in other words the end does not look like this.
    I want to take that cable you see, cut the other end off, and wire it into the 1 spot so I can connect it to the Boss daisy chain, instead of buying another daisy chain.
    I have a meter, I just need to make sure I wire it center negative.
    Any help would be appreciated.
  2. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    upload_2021-2-25_11-45-24.png You’re probably looking for something like this. Reverse polarity adapter. Right? Center neg to center pos?
    It’s easy to find these.
    Screen shot.
    EugeneWeemich and northernguitar like this.
  3. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Less invasive, no worries about reversing it.
  4. gitlvr
    Northern Va.
    No, I want t wire a different type of plug onto the end of the 1 Spot and don't want to wire it backwards. I want t keep the same polarity, just wire in a different plug.
  5. MatsEriksson
    MatsEriksson Tele-Afflicted
    Sweden
    Then, why do you need to figure out polarity as the headline said?
  6. telemnemonics
    This is the connector cable visual sound makes.
    gitlvr likes this.
  7. gitlvr
    Northern Va.
    I need to be able to tell if the two wires from the 1 spot and the two wires from the plug I'm wiring to them will be wired so that the polarity remains the same, and I do not accidentally reverse the polarity. Surely this is not difficult to understand?
  8. gitlvr
    Northern Va.
    Yes, as I said in my OP, that plug was changed out by my brother(deceased) to something else. I need to change it back.
  9. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    It’s not all that clear but I think I understand.
    Does the one spot have a portion of the original cable intact? Looks like it does to me. The cable should be coded. A dashed line is indicative of....
    Hold on i have one somewhere. Gonna check.
    gitlvr likes this.
  10. telemnemonics
    My old one spot wall warts do have a ridge on one side of the cable but no reference as to polarity or as to which side connects where in the molded plug on the end.
    A multi meter is cheap and handy, harbor freight or HD sells them and that would allow you to test the polarity.
    zippofan, Boreas and gitlvr like this.
  11. telemnemonics
    Or wire it up and see if a pedal works.
    Reversed polarity won't hurt the pedal, just wont function.
    gitlvr likes this.
  12. gitlvr
    Northern Va.
    Thanks. I just wired it one way, then the other. Got it sorted. Appreciate it
    ale.istotle, Boreas and telemnemonics like this.
  13. BorderRadio
    Phoenix, AZ
    Just for the archive, the text side of the wire is the center, or (-) lead. The ribbed wire is the barrel, or (+) lead.
    telemnemonics and gitlvr like this.
  14. gitlvr
    Northern Va.
    Thank you to everyone who tried to help. It is greatly appreciated.
    telemnemonics likes this.
  15. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    The confounder is some pedals use reverse polarity, which is where the above adapter comes in handy. But I never stray far from my multi-meter. I don't always know what it means, but I believe what it says.
  16. gitlvr
    Northern Va.
    Yep, I have that adapter, as I have an old MXR comp that needs it on my board.
    Boreas likes this.
