Need help; 5F1 build completely dead.
Discussion in 'Shock Brother's DIY Amps' started by teek_s, Sep 21, 2020.
  1. jmp81sc
    jmp81sc Tele-Meister
    Orange County
    Good that you found that. Don't be sorry, i've done 4 builds and still don't know much.
    Read, watch videos, learn how to read schematics and layouts, look at other builds; it'll start making sense. My best resources are Rob Robinette's site and Uncle Doug utube channel.
    John
    jtcnj and teek_s like this.
  2. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    So... Is the amp still dead or did you manage to get it sorted out?
    teek_s likes this.
  3. teek_s
    teek_s TDPRI Member
    United States
    The amp now turns on now!
    The amp itself still isn't fully functional, as whenever I attempted to turn it on with a 12ax7 the fuse as well as the rectifier tube blew. I believe it was due to improper grounding which has now been fixed. I'm waiting on a few new fuses, as I didn't have any extra on hand. I'll give updates if any more hitches are encountered along the way. Thank you very much, awasson!
    awasson likes this.
  4. King Fan
    Salt Lake City
    Progress, then. Good for you, and I hope you're right, and you've fixed the fault that was blowing fuses. Did you ever build a light bulb limiter? It can detect faults and prevent you going through fuses.
    Keep us posted, either way.
  5. Nickfl
    Nickfl Friend of Leo's
    Before you proceed...
    Build.
    A.
    Light.
    Bulb.
    Limiter.
    Fuses are cheap, power transformers aren't. A lightbulb limiter protects both.
    Wally, ArcticWhite and James Knox like this.
  6. awasson
    Vancouver
    We’ll be looking forward to a successful update. The nice thing about building your own amp is that you built it and you’ll be able to maintain and keep it running.
  7. teek_s
    teek_s TDPRI Member
    United States
    I'll get on it!
    King Fan likes this.
  8. King Fan
    Salt Lake City
    Lots of good LBL info online -- maybe too much? :D We discussed some of the confusion here.
    Nickfl likes this.
  9. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    I'm still confused and concerned by this.
    What is going on with this connection?
    Is it just floating around, uninsulated?
    What's the point of the heat shrink tubing on the neutral wire (white)?
    (And jeez, what were you thinking when you grounded the power cord like that?)
    If you are trying to insulate a soldered connection, you do it like this:
    Slide a piece of heat shrink over one of the wires. Wrap the tinned ends together and solder. Slide the tubing over the joint. Heat it to shrink.
    I think it's better practice to make power connections at a terminal strip, but if you're going to float joints like this, at least insulate them from the chassis.
    Now, about powering up. You don't test a new build by just plugging everything in and turning it on. Everyone make wiring mistakes, and you can easily blow your transformers, explode capacitors, burn resistors, etc.
    There's a startup test procedure. Here is how RobRob does it.
  10. Jeru
    Jeru Tele-Holic
    Chicago
    Teek — you’re going to get hurt unless you learn WTF you’re doing.
    AT A MINIMUM, Watch Uncle Doug’s videos on safety and light bulb limiter. Read Rob Robinette’s safety and startup procedures.
    Until then, go build pedals — a 9v battery can’t kill you.
    Wally likes this.
  11. teek_s
    teek_s TDPRI Member
    United States
    It's been insulated. I don't even know how I would try to fit a terminal strip into the 5F1 chassis, honestly.
    Done. All the parts of a lightbulb limiter are coming in a few days, I'll keep you all posted.
    jtcnj and dan40 like this.
  12. Wally
  13. teek_s
    teek_s TDPRI Member
    United States
    Alright, the amp is finally done and working! It's out of the 2 amps I own right now, it's the quietest. I'm super happy to be done with it after half a year! I'll do some bias testing without the limiter to make sure everything is okay in the tubes. I've also taken all the worry I got about the neutral wire to heart and I've fixed that and another joint like it. I can't thank all of you enough!
  14. awasson
    Vancouver
    Great News! Glad to hear you've got it up and running. Now that it's working it's time to plan the next one. This stuff gets a little addictive.
    King Fan and teek_s like this.
  15. teek_s
    teek_s TDPRI Member
    United States
    In fact, I already have a price chart for a 5F2A completely done! I think it's time to start saving up, lol.
    awasson likes this.
  16. jmp81sc
    Orange County
    Good deal, glad you got it going. I love my 5f2a, but you may consider a 5e3 deluxe, a little more amp without that many more parts.
    One way I have saved money is by building my own cabinets. You can make a decent cab with just a circular saw, sander and router.
    Take care
    John
    jtcnj, awasson and King Fan like this.
