Need an effects order switching solution
Discussion in 'Burnt Fingers DIY Effects' started by suburbansound16, Jul 6, 2018.
  1. suburbansound16
    suburbansound16 TDPRI Member
    Delaware, OH
    Hey there!
    I'm trying to figure out a way to make a bypass looper type of pedal but with an uncommon function.
    What I need is to be able to use a 4pdt switch to toggle between running an OD into a Compressor, into a noise gate vs just running into the compressor. I really need to keep the compressor "always on", but in between the drive and noise gate when they are active.
    Eg. - guitar
    - looper
    - compressor
    - looper
    - amp
    Vs
    Guitar
    Looper
    OD
    Compressor
    Noise Gate
    Looper
    Amp
    Is there a way to do this?
    Again, I need to maintain these two orders and the compressor needs to always be on.
    Thanks!!!
  2. EddieLocrian
    EddieLocrian Tele-Afflicted
    Isle-of-Wight
    Build a Y guitar cable and have 2 rows of independent pedals?
  3. sirbergersworth
    sirbergersworth Tele-Holic
    St. Louis, MO
    Couldn’t you do this without a looper?If you only have 3-4 pedals, I thinks looper just complicates things.
  4. suburbansound16
    Delaware, OH
    I'm really trying to place 3 effects in the same enclosure and operate it on two footswitches. One is a master bypass and the other toggles between a compressor circuit and the OD to Comp to Noise gate circuit. I thought it might be more simple in terms of a looper.
    I don't want any funky cables or any more switches than that because this goes onto at pedalboard with 15 other effects at the end of the day.
    The goal is to have a pre-dialed-in clean and dirty tone, using either the compressor or the 3 effects chained, in that specific order.
    Thanks
  5. luckett
    luckett Banned
    That's simple. You just need to put two bypass loops with four jacks on your 4PDT and put the comp in between the two loops. It's basically two bypass loopers on one switch.
    suburbansound16 likes this.
  6. suburbansound16
    Delaware, OH
    Thanks a lot!
    Pretty sure either was just over complicating it in my head. Appreciate the response haha
    My only other question is how to add a status LED to that configuration?
    I can only think of how to use a 4PDT switch as the two typical bypass loop style switches, but that uses all 12 terminals.
