Need Advice on a Dull Sounding Tele Build
Discussion in 'Other T-Types and Partscasters' started by TommyGunz, May 22, 2020.
  1. shadycakes
    shadycakes TDPRI Member
    Virginia
    No, I've been lurking for over a decade and only joined recently. Just trying to pour back into the community that taught me so much.
    How are you measuring pickup height? Fender measurements are taken from the top of the polepiece to the bottom of the string, with the string depressed at the highest fret.
  2. TommyGunz
    TommyGunz TDPRI Member
    Elgin, Texas
    I just ordered a Wilkinson vintage bridge with brass saddles as well as a set of 64 pure vintage tele pickups. I'll get them on Sunday and hopefully get this settled. I am more thinking it's the bridge because of the dead sounding acoustic strumming tone. It sounds the same electrified. The pickups I ordered are light waxed so I could get more of the guitars natural tone through the pickups. Kinda makes sense it sounds dead electrified too.
    I'm playing through a Fargen Blackbird (Deluxe reverbish clone) and a Champion 600 Modified by Ben Fargen through a 10" Jensen. Compared to my strat, it's night and day. It's like going from a 3ft to a 50 ft instrument cable. Its very frustrating.
    KW1977 likes this.
  3. shadycakes
    Virginia
    I learned about thick plate tele bridges the hard way, like you did.
    I built two identical guitars, one with the Gotoh six-saddle "Modern Telecaster" bridge, and one with a cheap GFS Wilkinson-branded vintage style ashtray. I was blown away by how much more spank and twang there was with the Wilkinson. Immediately ordered a second one. Lesson learned.
    zippofan, KW1977, bgmacaw and 2 others like this.
  4. shadycakes
    Virginia
    Sounds like a good plan, OP. In the meantime, check out the pickup height section of this setup guide: https://support.fender.com/hc/en-us...ow-do-I-set-up-my-Telecaster-guitar-properly-
    The Fender specifications for pickup height are by no means gospel, but I find them to be a good starting point.
    aadvark and TommyGunz like this.
  5. TommyGunz
    Elgin, Texas
    Thanks for the recommendations! I'm gonna swap the bridge first and see if that's the issue. If not, then I'll pop in the '64 pure vintage tele pups I just ordered.
    As for the wiring, that's been another issue. I did bypass all the controls and wired direct to the output jack to eliminate that as a possible problem. The diagram provided by RS did not work correctly. It is a standard diagram and should work. I triple and quadruple checked and everything is where it should be, but both pickups are on to some to degree in each position. I just looked at the switch up close and ended up figuring out a different wiring scheme to get it so each pickup is correctly isolated in positions 1 and 3. I reached out to RS a few days ago but haven't heard anything. I'm wondering if he shipped a funky 3 way by mistake. He has responded promptly in the past...I'll call him today.
    Sinphenom likes this.
  6. TommyGunz
    Elgin, Texas
    Yep, that's exactly how I do it.
  7. TommyGunz
    Elgin, Texas
    Good point! What's your experience with tight vs. loose neck pockets? This tele's is TIGHT.
  8. Matthias
    Matthias Friend of Leo's Gold Supporter
    Check your neck pickup isn’t too close to the strings.
  9. Sinphenom
    Sinphenom TDPRI Member
    India
    Sounds like a plan... sometimes bad switches and pots can be problematic. Since you are getting the wilkinson Bridge... that’s definitely a great thing in itself. They are really good. I love mine :)
    Jim622 and shadycakes like this.
  10. shadycakes
    Virginia
    Perfect.
    You can try lowering 1mm or so and see if things brighten up. If not, and the new bridge still doesn't resolve the issue, I'd look at some new pickups.
  11. MonkeyJefferson
    MonkeyJefferson Tele-Holic
    Nonurbana
    I don't buy into a lot of tone voodoo, but the bridge thickness matters. That's a big reason I like that 62RI set. And that dang pickup in there salts the fields and burns the orchards of your guitar enemies.
    KW1977 and baiff like this.
  12. baiff
    baiff Tele-Holic
    FLOOR-AH-DUH
    I have a set of the Fender PV64's in my Shoreline Gold MJT and they are awesome! Great middle position tones and a really great clear neck pickup. I set them with the nickel method and it seems to balance them out fine.
    TommyGunz and MonkeyJefferson like this.
  13. doghouseman
    doghouseman TDPRI Member
    Hoboken NJ
    Musikraft pine body
    I have built a lot of guitars and I think this is your problem.
    Swamp Ash or Maple is what most teles are built from.
    Especially since you have a rosewood neck, in combination with the pine, you are not going to have a lot of spank.
    aadvark and Jukers like this.
  14. 63 vibroverb
    63 vibroverb Tele-Holic
    Lititz, PA
    3mm sounds awfully thick for the bridge plate, is that accurate?
    The stock Fender Pat Pend bridge is .048”. I like the Fender Highway bridge plate at .060” but no thicker than that.
    I suspect the pine body may be playing a part in the dullness, but I would try a thinner bridge and stainless steel strings before anything else.
    aadvark and doghouseman like this.
  15. MonkeyJefferson
    Nonurbana
    I feel like we're letting too many people know about a secret fishin' hole. Turns out, there's this company called Fender, yup, F-E-N-D-E-R, and these guys have been makin' sweeeeet pickups since the 50's, and their prices are way below boutique.
  16. baiff
    baiff Tele-Holic
    FLOOR-AH-DUH
    Yup, a telecaster is not rocket science. Keep it simple as there is a reason why this simple design has lasted so long. I had a buddy that spent about $300 on "premium" upgraded hardware from a very popular online store. While the stuff looked great and he was using Mare Hayrides the tone and reaction was not what he expected. He put on about $40 worth of Fender hardware on and it sounded like a vintage tele should. Not saying the expensive stuff is junk but there is a lot of hype included.
  17. baiff
    baiff Tele-Holic
    FLOOR-AH-DUH
    Shhhh!!! If people only knew that you could get an awesome set of pickups for less then $100 (OV's, PV64's) the world would implode......more then it is doing right now.
  18. TommyGunz
    Elgin, Texas
    I played around with pickup height but that soft overall tonality is omnipresent.
  19. TommyGunz
    Elgin, Texas
    The consensus so far seems like bridge thickness is a factor. I'll try to record some acoustic clips before and after to share.
    MonkeyJefferson likes this.
  20. TommyGunz
    Elgin, Texas
    I got the 3mm from Gotoh's specs. It's a slab.
    I had also been pondering if it's the pine, but I hadn't heard that about other pine builds.
    aadvark likes this.
