Need Advice on a Dull Sounding Tele Build
Discussion in 'Other T-Types and Partscasters' started by TommyGunz, May 22, 2020.
  1. chewy 65
    chewy 65 TDPRI Member
    Hamilton ON Canada
    I’ve got a ’52 RI and I have some thoughts:
    I refinished mine because, in a spectacular display of not getting the point, Fender put a thick poly undercoat under the thin lacquer coat, which conventional wisdom would say is a resonance killer. So, personally I would steer clear of any Polyurethane products like Varathane.
    I’ve had the original pickups in mine, had them rewound to Broadcaster specs, replaced them with O.C. Duff pickups and then replaced the neck PU with an LSL. In all that the guitar never sounded dull. So I doubt if it’s the pickups.
    Also if you want traditional Tele sound you might want to use a traditional Fender bridge assembly, after all they say that strats just don’t sound right without the thin steel saddles.
    One last thing, does your bridge pickup have the copper plated steel support plate on the bottom? That has a lot to do with the sound.
  2. chewy 65
    Hamilton ON Canada
    I realize now that my last point kind of negates my second point. What I was trying to say is that someone emulating tele pickups likely wouldn't veer that far from the mark
  3. mstrjay4
    mstrjay4 TDPRI Member
    Las Vegas, Nevada
    I can appreciate your frustrations. The first course of troubleshooting should be your pickup height especially the neck pickup which is almost always set too high. Lower it first slowly, you will will get clarity and a loss of volume as well. Don’t worry about volume focus purely on clarity and tone go completely by ear and not by the appearance of the height, then work on the bridge pickup as well. The hotter the magnet the stronger the string dampening is. Your first clue was when you mentioned acoustically it is dull as well since this has nothing to do with the wiring.
    Volume balancing between the two pickups is a needless rabbit hole, just get it as close as possible without sacrificing tone. The neck will never be able to have the output of the bridge due to the way they are engineered differently and positioned.
    Please share what you find,
    Jay
  4. bebenavole
    bebenavole Tele-Meister
    ZG
    try another neck
    Telenator likes this.
  5. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    Will everyone look at the previous posts, please? Some things keep getting repeated over and over. And over.
    KW1977 likes this.
  6. TommyGunz
    TommyGunz Tele-Meister
    Elgin, Texas
    HUGE UPDATE!!!!!
    First sorry for the delay in getting this wrapped up...Last week of school (I'm a teacher) and had a lot to get done.
    Let me rundown what I was able to do today in order:
    1. I replaced that 3 way switch that was causing problems separately. Billy at RSGuitarworks sent me another one (1st class shipping btw) and it got here today. Great customer service.
    2. I installed the 64 Pure vintage Fender pickups and they sounded great...better than anything I'd heard before. I recorded a sound clip starting at bridge, middle, then neck positions. To my ears, that made a big improvement right off the bat. I was really starting to worry that the Cavalier pickups were just not up to par. Now previously I stated that I had bypassed the electronics and wired the Cavalier pickup leads direct to the output jack and I didn't notice a difference in the dull sound. However after changing this 3 way, I did notice a significant difference. When I wired direct to the output jack, there must have been something wrong in my methodology as I cannot account for why it sounded blah both ways and now it sounds much better. But there's more...
    3. I installed the Cavalier pickups back in. I recorded samples too. They have a bit more of everything I love about tele pickups. as Rob says, they have the screech. Some asked about the specs so here they are. Bridge: 7.81k, 1950 turns of 43ga, A3 magnet. The neck measured at 6.99k, 1950 turns, not sure on magnet or gauge wire...wasn't noted on the bottom of pickup. At this point I was much happier about my purchase from Cavalier and was definitely going to stick with those pickups. But there's more...
    4. I was also advised to do the neck pocket trick by a several people following this thread. It took their advice. Loosened the screws 1/4 turn, heard some cracks and pops, re-tightened the screws. The E A D and G stings went flat so I re-tuned the guitar noticing immediately a change. It might not be so apparent in the audio clip but it made a change. Specifically, I was getting a weaker sound from the E and B strings and other various spots around the fretboard. Not any more. This last step really brought the guitar alive overall. I really was surprised by the difference. I also recorded a clip with the Cavaliers after the neck pocket reset.
    This being my first post, I really wanted to thank EVERYONE for the positive comments and support as I worked through my tele build. I hope I was able to contribute something positive to the group that others may find helpful in their tele-adventures.
    teletimetx, P Thought, JJOVa and 7 others like this.
  7. moosie
    Western Connecticut
    Hi-Beams are nice, lively strings. I'm not a string connoisseur though, so I usually stick to my reliable and cheap D' EXL-110s :).
    TommyGunz likes this.
  8. koolimy
    koolimy TDPRI Member
    Congratulations! I'm glad you were able to solve your problem. It's even better that you didn't have to do much other than change the faulty switch! Very glad you were able to keep that beautiful tele body.
  9. peterpaul
    peterpaul TDPRI Member
    new haven, ct.
    Now, Please Install a Lollar 52 Set.
    You Can Thank Me Later
  10. 63 vibroverb
    63 vibroverb Tele-Afflicted
    Lititz, PA
    Wow, never experienced a bad toggle switch before. At least to the extent that it was affecting the tone like it did for you. Glad everything got sorted, now you can finally enjoy your guitar!
  11. TommyGunz
    Elgin, Texas
    Yeah, me neither. I still have that 3 way switch so I think I'm gonna look it over with a microscope to figure out what's up with it.
  12. TommyGunz
    Elgin, Texas
    Oh, I had to do plenty. I swapped out bridges, swapped out pickups, swapped out 3 way switches, experimented with wiring, and adjusted the neck fit in the pocket. They all had a measurable effect on the tone of the guitar. Pretty crazy. My strat was so much easier to build! I guess the ones you toil over are the ones you love the most :)
    koolimy and Sinphenom like this.
  13. TommyGunz
    Elgin, Texas
    Nothing cheap about D'Addario except the price. I've played them for most my time and they have been very reliable, last a long time and sound great.
    Lizzard likes this.
  14. TeleTucson
    TeleTucson Tele-Afflicted
    Tucson, AZ
    Ahah! After 15,485 views and 332 posts, we've learned that the secret to monster tone is the 3-way switches!
    And ... the influence of bad ones is so powerful that just their presence in the guitar can kill the tone even when they're completely disconnected from both the pickups and the output jack.
    I love TDPRI.
  15. TommyGunz
    Elgin, Texas
    Yeah, it cursed. Not sure if I can prove that empirically, but let's go with it.
  16. drmordo
    drmordo Tele-Afflicted
    Miami, FL
    Ok. So what exactly fixed the problem? You think it was the switch?
  17. Sinphenom
    Sinphenom TDPRI Member Silver Supporter
    India
    Yaaayyyyy[emoji1487] congratulations brother
  18. Sinphenom
    India
    Sometimes molten solder can seep in and mess up the internals....
  19. Sinphenom
    India
    Please post some of your playing with this new updated setup! It would be cathartic to a lot of us who have been following this thread over the last few weeks!
    FuZZBoY likes this.
  20. SecretSquirrel
    SecretSquirrel Friend of Leo's Silver Supporter
    PNW USA
    Great thread! And glad you got your guitar sorted out.
