Need advice for this strange issue
Discussion in 'Acoustic Heaven' started by screefer, May 6, 2021.
  1. screefer
    screefer Tele-Holic Silver Supporter
    kildonan
    This tenor from my previous thread..https://www.tdpri.com/threads/need-new-guitar-advice-is-this-normal.1070290/ sounds nice but very quiet. I thought it was due to bridge placement re 14 frets to the body.
    I go to poke an LED mirror in the hole to see what the bracing is for installing a Schatten or JJB type pick up and there is this block of foam!
    Google yields nothing so I turn to you folks to, once again, edify me as you did in my previous thread.
    I tried to pull the foam out but it didn't come easy and I don't want to damage the bracing. I can grab it and squish it but has to clear the bracing and I'm chicken.
    Is this normal? If so, what is the function?
    No wonder it is quiet?
    A big pre-thanks
    Bill likes this.
  2. Leonardocoate
    Leonardocoate Tele-Meister
    Ohio
    my guess is that it is for shipping...cut it out in pieces...I would
    screefer likes this.
  3. Gardo
    Gardo Tele-Afflicted Silver Supporter
    Lancaster Pa
    This is not normal, I’ve never seen anything like that . It must be removed , it would be like singing with a mouth full of marshmallows
    Boreas, ieatlions and screefer like this.
  4. screefer
    kildonan
    I yiped it out of there. Pretty tight fit.
    I guess the seller should add 'looking into the sound hole' as one of their inspection routines, eh?
    On the other hand, maybe I should have looked sooner.
    Anyway, night and day... I've got a real Tenor now!
    Big Thanks to leonardo and gardo for straightening me out.
  5. screefer
    kildonan
    There should be room to fit a JJB 220 two transducer, eh?
  6. Lies&Distortion
    Lies&Distortion Tele-Afflicted
    SE Michigan
    An attempt by the previous owner to cut feedback? My guess.
    MatsEriksson likes this.
  7. screefer
    kildonan
    It was a brand new unit.
  8. Lies&Distortion
    SE Michigan
    Oh. Missed that
  9. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    That’s better!
    Maybe it was like a permanent do not eat packet.
  10. Lies&Distortion
    SE Michigan
    I didn't read linked thread.
    That's just weird. Place selling it didn't know it was in there? Oh well, sounds better now
  11. trev333
    Coolum Beach,Australia
    It's probably crushing protection for transport.... so the top doesn't cave in if a package gets put on it.... or a boot..;)
    985plowboy likes this.
  12. screefer
    kildonan
    Trev is probably right but hows about a heads up to the dealer?
    This here chunk of foam is gonna lose to a boot!!
    Has anyone ever seen this before?
  13. ElJay370
    ElJay370 Tele-Afflicted
    Los Angeles, CA
    At Taylor they'd wedge a piece of foam like that into the sound hole to prevent lacquer, buffing compound, and whatnot from getting inside the guitar during the finishing process. Maybe that's what it is.
    Wally, Deathray and Steve Holt like this.
  14. screefer
    kildonan
    No finish on the foam and some wicking of the finish inside the sound hole.
    Bits of sawdust. Maybe I'll rig up an tube attachment to a vacuum cleaner?
    More pix of bracing...
  15. Gardo
    Lancaster Pa
    That’s incredible
    Glad you found it
  16. Freeman Keller
    One possibility is that the foam was dampened to raise the humidity in an dry guitar. I do this all the time with a sponge but I put it in a baggie with holes in it. I question the need for internal support if the guitar was in a good hardshell case and that in a good box when it was shipped to you. Otherwise, good catch, enjoy your tenor.
    I install lots of K&K piezo's on the bridge plate, the JJB should work fine
  17. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Maybe QC found a loose brace and used the foam to re-glue it! Bizarre... My best guess is a foam plug during final buffing. They hung the guitar afterward and it slipped out of sight. Then everyone down the line was brain-dead that day. How you could install a set of strings and play it without noticing it is beyond me. I don't think it would do anything to keep the top from crushing.
  18. screefer
    kildonan
    Very interesting. They would have to have really crammed it to get it in. A smaller chunk in a baggie would be way easier.
    Thanks for the OK re the piezo.
  19. billy logan
    billy logan Tele-Meister
    weatherford tx
    My brand new $100 flattop had a wad of crumpled-up newspaper in it the size of a rabbit. Maybe the Guangzhou Chronicle, idk.
    edit- cut a wedge of foam that fits snugly under the string-ends on the headstock. That way, in a close-miked situation, you won't hear the inside-a-piano treble ringing sound if you end a song with a loud strum and mute the strings immediately.
    but - A factory representative might show up at your place asking for the foam cube back - so maybe you shouldn't cut a wedge off from it.
    screefer and Wally like this.
  20. Wally
    Tenor...I would want to be measuring that bridge plate in front of the bridge pins. Whether or not a pickup unit will fit will depend on the angle of the x-bracing and the width of that bridge plate.
