Need a schematic for a humbucker in an esquire
Discussion in 'Tele-Technical' started by bionic, Apr 23, 2010.
  1. bionic
    bionic TDPRI Member
    montreal
    Just routed out and installed my "shaw" PAF in the neck position and can't find a schematic. I'm looking for:
    1st position - humbucker with tone
    2nd position - bridge with tone
    3rd position - bridge no tone
    Basicially I have the last two positions so just want to get rid of my "cocked wah" .47 cap and be able to use my tone for the neck pick up
    Thanks in advance
  2. bionic
    bionic TDPRI Member
    montreal
    O.K. now that I've really put some thought into it here's what I really want
    1st position: neck humbucker with tone control
    2nd position: split series bridge humbucker with tone control
    3rd position: bridge humbucker with out tone control
    While I've got my sleeves rolled up I think I'll also reverse the control plate so I can have the volume right at hand for easier swells
  3. cc9cii
    cc9cii Friend of Leo's
    Sydney
    Not following... you have two humbuckers?
  4. bionic
    bionic TDPRI Member
    montreal
    Yep, it's a two conductor humbucker in the neck and a four conductor humbucker in the brige
  5. cc9cii
    Sydney
    OK, I'll post something shortly.
    EDIT: Try this.
  6. bionic
    bionic TDPRI Member
    montreal
    Cool, thanks:lol:
    I have the "cocked wah" setting cap in there now. What cap will I need with two 500 K pots?
  7. cc9cii
    Sydney
    I thought you wanted to get rid of that cap? I'm not sure which value will sound good in your guitar... get a few different ones and try them all :)
  8. bionic
    bionic TDPRI Member
    montreal
    Soldered it up like the above schematic and now I'm not getting any sound. What should be checking for?
  9. cc9cii
    Sydney
    If nothing is working, start from a known place and work backwards.
    1. touch the middle lug of the volume pot with the guitar plugged in and amp tuned on. You should hear a loud buzz from your amp.
    2. touch the top lug of the volume pot (not the end that is grounded) and you should hear a buzz from your amp. Try turning the volume knob and the buzz should change volume.
    3. touch the two lugs with orange wires (see diagram) on the switch, one at a time. You should hear a buzz from your amp each time.
    4. touch the two lugs with green wires on the switch. You should hear a buzz from your amp on two of the three positions.
    5. repeat on the other side of the switch, with each of black, red+white and white (neck) wires as you move the switch tip.
    Let me know what you find.
  10. bionic
    bionic TDPRI Member
    montreal
    screwdriver is out and will check now
  11. bionic
    bionic TDPRI Member
    montreal
    Oops, forgot to add the orange wire. That's sorted and now my bridge humbucker without tone works. Got the proper buzzes but not with the green wires and they seem to be accurate to the diagram:confused:
  12. cc9cii
    Sydney
    If things are working don't worry about it:p
    It's probably the tone circuit sending the high freq noise from your finger/screw driver (a.k.a antenna) down to ground.
