need a picture of classic vibe control wiring
Discussion in 'Telecaster Discussion Forum' started by buckwalder, Jul 19, 2014.
  1. buckwalder
    buckwalder Tele-Meister
    utah
    I don't know if this is normal or if the guitar has a problem. The guitar in question is a CV vintage blond telecaster.
    The issue is that when I turn down the tone knob I lose quite a bit of volume. I took out the control plate and inspected the wiring but failed to see anything wrong, everything looked ok. What I did find strange, was that both leads of the tone cap are wired to the tone pot but after some research I found that this is the way these guitars are wired.
    So if anyone can provide a detailed picture of the actual stock wiring of this guitar I would be grateful.
    If this volume loss is normal then I'll just live with it.
  2. xtrajerry
    xtrajerry Doctor of Teleocity
    Lehigh Valley, PA
    Pretty much the way things work.. there are a couple things you can do to help.. Search here for Fezz Parker mod, and Treble bleed.. if you're handy with a soldering iron either one should take 5 minutes.
  3. buckwalder
    utah
    Thanks for the help. I guess if this is normal for a telecaster I will leave it alone for now.
    However, the wiring diagram shown on this page is not at all how my tele is wired. For instance, Mine has only one wire going to the output jack vs two. And the capacitor is soldered to the middle lug of the tone pot while the other leg of the capacitor is soldered to the tone pots casing. In the above wiring diagram the capacitor is soldered to both the volume and tone pots.
    I have seen pictures on (google images) of this models controls and they are the same as mine and not like the diagram provided here. The problem is, that those images aren't detailed or big enough for me to see everything.
    Maybe there's two different wiring configurations on these guitars.
    Thanks again
  4. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    It's functionally the same.
  5. gypsyseven
    gypsyseven Friend of Leo's
    Germany
    Correct me if i´m wrong, but the CV´s got the "modern wiring" and not the 50´s wiring...I would and probably will go for the 50´s wiring in my CV Telecaster...
    The other option would be to go for that "treble bleed" thing - very easy, just solder that cap to the volume pot...if i´m not wrong....
  6. buckwalder
    utah
    Good to know, I may try that.
  7. soulman969
    Englewood, CO
    Yes, the CVs have modern wiring.
    When you turn down the tone know you're rolling off the highs so it's more the perception is the guitar is losing volume when all it's really doing is losing those highs and the guitar sounds muffled and darker.
    Try replacing the stock .047 tone cap with one of a lower value like an .015. Less highs will be lost initially as you roll of the tone and the tone won't become muffled and dark as quickly.
    The treble bleed mod is a different cat altogether. It's attached to the volume pot and prevents highs from rolling off as you reduce the guitar volume not the tone. The tone remains the same at all volume levels.
    So you have a two pronged approach to try. 1) replace the tone cap to preserve more high end as you cut back on the tone knob, and 2) install a treble bleed mod on the volume pot to retain highs as you reduce volume. I think the combination of these will help you get what you want.
  8. xtrajerry
    Lehigh Valley, PA
    Three prong approach if you include the Fezz Parker mod.. The lower cap value is a good idea too.. that would be my first move.
  9. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    The diagram being a 50's Tele has nothing to do with 50's wiring. It is the modern scheme.
  10. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
  11. BUILTACASTER
    BUILTACASTER TDPRI Member
    OKLAHOMA
    Look at Emerson if you go this route. He hand makes several tele harnesses. I recently installed a four way setup for someone and it was easy to install and very neat and tidy. I'm not big on the four way thing but it worked well and I was impressed at what I saw when I opened the box. They're about half the price of the one in the link above too.
  12. gypsyseven
    Germany
    Just did the treblebleed mod to my 50's CV and i'm more than satisfied with the result!
  13. soulman969
    Englewood, CO
    Right, three if you do this mod in place of the treble bleed but remember these two only affect the treble lost while lowering the guitar volume buckwalder. Your main issue is with the tone pot so swap that tone cap out for one with a lower value and see where that leaves you.
  14. wrxmania
    wrxmania Tele-Afflicted
    Scotland
    Any wiring diagrams and suggested caps for the three prong attack? May do it to mine.
  15. sjtalon
    I would:
    Fezz Parka, then .022µF cap on the pot.
    All the Fezz mod is is soldering the wire from the tone pot to the MIDDLE volume pot terminal, instead of the outer ( with the wire from the selector switch).
    I would try that, then if you don't like the treble loss (high loss) when you turn the VOLUME pot down a tad, you could do the high pass filter. That being a .001µ cap across the vol. pot terminals (not the grounded one).
    If you still find the tone pot too aggressive ( gets too muddy from, about 6-0) then go with a .01 or .015 cap on the tone pot.
