Need a Compressor
Discussion in 'The Stomp Box' started by Southpaw Tele, Jan 15, 2018.
  1. Southpaw Tele
    Southpaw Tele Friend of Leo's
    The Golden State
    Didn't turn on the Gerbil (Rat) #RichardGere #HashtagsDontWorkonTDPRI
  2. PBO Blues
    PBO Blues Tele-Holic
    Chatham County, NC
    THANKS for the clarification! Perfectly reasonable. I try to preserve the highs (and the pretty click of the pick) with a 50/50 wet/dry blend and the internal high cut filter switch off. (I do admit that the internal dips are a bit of an annoyance. The price of compactness.)
    Cheers!
    Tootle likes this.
  3. Clash Telecaster
    Clash Telecaster Tele-Meister
    New York
    This is true.
    I was monkeying around with my BOSS CS-3 yesterday and it sure does compress. Squish. A Telecaster played through a CS-3 is the perfect example if one wants to demonstrate what a compressor does.
    The CS-3 does accentuate the single coil hum (it is hissy) but if you use an NS-2 Noise Suppressor pedal that stuff vanishes.
    [​IMG][​IMG]
    OlRedNeckHippy likes this.
  4. blille
    blille Tele-Afflicted
    Bay Area - California, USA
    A CS-3 was my first comp but unmodded it is IMHO unacceptably noisy. Super squishy too, but I still use one for funk, so it has its place IMHO again.
    Phrygian77 likes this.
  5. Darrell D
    Darrell D TDPRI Member
    Canton, GA
    Ditto what he said. The Xotic Compressor is always on for me!
  6. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    Asking for compressor suggestion is second only to OD. If you like the squishy Dyna Comp thing, the TC has that mode on it and it does really well. Beyond that it does the cleanest transparent, multiband, paralell compression! All the good stuff with none of the bad. They go for $80 used. Super clean chimy goodness.
    lefty73 likes this.
  7. luckett
    luckett Banned
    That font looks kind of like the Keeley font, but the controls are a bit different and the Keeley isn't orange. The Keeley is based on a Ross/Dyna Comp.
    Southpaw Tele likes this.
  8. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Usually around $100, but someone on Reverb is selling new ones at $50. I love mine with Tele, Strat, and bass.
  9. Southpaw Tele
    The Golden State
    I think I'm going to go with a Dyna Comp. I'll report back
  10. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    I use a Kelley 4 knob, not as an effect pedal, but as a clean boost and to even out the volume between strings. I get all the 'compression' I need from my Mesa Boogie. My suggestion would be to decide what you need from a compressor and then shop with the help of a good salesperson or tech. In the end, your best decision will be to spend what you need to spend to get what you need. Too little spent on something that doesn't do the job is money down the drain. A lot of money spent on something you get bored with is a lot of money down the drain. Do it once and do it right.
  11. PBO Blues
    Chatham County, NC
    This may be the best advice I've ever read on this forum. Priceless.
  12. Southpaw Tele
    The Golden State
    I really liked how the software compressor evened out volumes among strings and highs and lows in my strumming. There was also a clarity to my playing. Hard to describe.
  13. Platefire
    Platefire Friend of Leo's
    North Louisiana around Many
    I use a CS-3 and a dyna comp behind it. Use the CS-3 for light compression that I leave on all the time and dyna for the squash that I bring in occasionally as needed. The dyna is nice even though it only has two controls--level & compression. The tone pretty much follows what ever your amp is set on but I would say it colors slightly with a little fatness that I don't seem to mind:>) because when I kick it in, I'm usually playing on the bridge PU on a strat, so a little mellowing is nice.
    One of the hard things with a compressor I always had problems with was getting the volume right so when you kick it in it's not overbearing or then to low. So the way I do it is pretty much set the level to match the guitar volume wide open to amp without anything else on by A/B'ing it. Once I got a match, I boost the dyna level slightly because I've found a perfect match ends up being a little too low for a lead ride once you kick it in and the ducking starts. Of course what I'm describing is running guitar into a clean amp set at moderate volume. Setting the level that way sounds too loud when your playing by yourself but when your playing with a band it fits right in the pocket. Platefire
    jddub440 likes this.
  14. richey88
    richey88 Friend of Leo's
    philly suburbs
    Yeah I had the original DOD, loved it in the bedroom, couldn’t tell much at a crappy gig (my gigs, usually not miked, small rooms, crappy is a bit harsh, I always have a good time), so it was passed over for a boost. The videos here sound great, good luck with your squash quest!
  15. Southpaw Tele
    The Golden State
    Dynacomp is en route. Got one on Reverb used for $40. Will report when it shows up. Thanks all!
  16. Wrong-Note Rod
    Wrong-Note Rod Poster Extraordinaire
    atlanta
    good luck with it!
    compressors are odd beasts. Depends on how you play, what kind of band you're in, how you're going to use it... all kinds of factors.
    Personally I dont like the Ross style... the attack is too hard, theres this pop or plink sound at the front end of every note. the squish is great but I dont like that sound. Whats crazy is that I know a few guys who love the Ross and when I played their guitar-pedal-amp, I mentioned the "pre-note-pop" and they swear they couldnt hear it.
    so its different for every player. I went the other route... old DOD Milkbox, fabulous compressor.
    Not telling you what to do here. Decide for yourself.
  17. brbadg
    brbadg Tele-Afflicted
    Timonium,Maryland
    I want the Philosopher's Tone mini,but the Biyang Baby Boom Compress X
    is really good to get started with.
  18. E5RSY
    Georgetown, TX
    Do you have the one with the funny dairy terminology labels, or the other one?
    Is there a real difference between the two, or is it just the graphics?
  19. Wrong-Note Rod
    atlanta
    I have the old one with the funny dairy labels. I have never heard the other one.
    Its so good, that when the footswitch finally wore out, I went looking for a replacement... tried the Wampler, which was not my thing. Eventually found a guy to repair the Milkbox footswitch.
  20. Fearnot
    Fearnot Friend of Leo's
    Decatur, GA
    I bought a Milkbox on Rod's recommendation. It's great, the only compressor I've ever liked.
    jddub440 and Wrong-Note Rod like this.
