Neck wood/ Fretboard interface
Discussion in 'Tele Home Depot' started by Slowtwitch, Nov 12, 2019.
  1. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    I've now built 2 necks and just finishing the 3rd.
    On both the first 2 I found that over a period of a few months, the seamless transition between the neck wood and fretboard there's a very slight ridge which formed you can feel. In other words there's been differential expansion/ contraction of the 2 types of wood.
    The neck was finished to 2000 grit, neck is oiled
    I sanded it flat again on my first neck, so all smooth and seamless again, but I not sure if this will happen over time again and more importantly, how do I prevent this from happening?
    Also, is this a common occurrence?
    Treadplatedual likes this.
  2. guitarbuilder
    Yes, woods move at their own rate. I like to use quartersawn fretboards because there is less shrinking and swelling across the grain. It may have something to do with the relative humidity in your area too and possibly your glue joint. Ideally small guitar manufacturers keep their humidity around 50% if they can.
    Slowtwitch and Treadplatedual like this.
  3. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    Maybe the lumber you used did not have enough time to settle in after gluing and before sanding?
  4. Ronkirn
    Jacksonville, FL
    woods will always shrink and expand at differing relates, even they were both the same species.. It's just one of the joys of wood working..
    rk
    eallen, Slowtwitch and Vibrolux59 like this.
  5. Slowtwitch
    South Africa
    I leave the neck clamped for 48 hours when gluing the fretboard on, just to be safe.
    We do have about 70-80% humidity, but then again it doesn't vary that much i.e. the wood didn't go from very dry to very humid conditions.
  6. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    The ridge may also be "glue creep" which is not uncommon with PVA glues.
  7. Ronkirn
    Jacksonville, FL
    consider,. we are now in that time of year when the frets ends make their presence known....
    it's not the frets that are expanding... it's the wood shrinking... since both the Fingerboard AND the neck, whatever wood it may be made of will both shrink... the differential may be darn near unnoticeable... but that does not mean "unnoticeable" is the norm.. Wood is wood.. it's as unpredictable as your 15 year old daughter,.... there are good days, then there are those others...:rolleyes:
    rk
    Slowtwitch likes this.
  8. Jim_in_PA
    And to further clarify, most seasonal movement is across the grain, so with the grain on the neck for both fingerboard and neck structure being lengthwise, any seasonal "shrinkage" is in neck width. The metal frets, on the other hand, don't really change perceptibly.
  9. Slowtwitch
    South Africa
    well it sounds like this is normal and expected
  10. guitarbuilder
    Well you are in Africa....not sure whether you have heat on or not...:). Your choice of woods could have a bearing on this too. Some woods have a higher degree of dimensional stability. You can probably find that out in some type of Engineer's handbook. For example ebony would be less stable than say mahogany. This instability rears its head on necks that aren't built in climate controlled conditions. I learned my lesson on an ebony fretboard on maple neck built here but ended up in California.
