hydra19
I have a bit of a problem recently...I have a Superstrat, M-II by ESP, when I bought it, it came setup from the factory with 10 gauge strings, and all was fine. Eventually I put DR String 50-10 set, essentially a 10-48 set, with the treble strings a lighter gauge, and had it like that for a year or so. I recently put 9-46 set on it and now the neck is very flat, no relief at all. I tried moving the truss rod to the left a bit, but it was still straight, so I was doing that for a few days until the truss rod nut slipped off, it's that loose, and there is hardly any relief.
This guitar never needed a setup before, and needed none with the different gauges I've tried but now, no matter what, the neck is really straight and I doubt the strings have so little tension. What should I do? Try a different set of strings? Leave it without truss rod nut until the neck gets some relief? I never had this situation before
