Neck tele pickup a little loose
Discussion in 'Telecaster Discussion Forum' started by RoCkstAr256, Nov 29, 2018.
  1. RoCkstAr256
    RoCkstAr256 Friend of Leo's
    Poland
    I gave guitar to luther its Fender standard telecaster MiM and he swapped new pickups today. The new ones are Texas Special. One thing that bothers me is the fact that neck pickup is a little loose . It can move slighlty back and forth. Im nto sure if i had it the same before. Any ideas?
    Crobbins likes this.
  2. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    installed correctly???
    put a piece of foam behind it
  3. 8barlouie
    8barlouie Friend of Leo's Silver Supporter
    Southeast Massachusetts
    All pickups are like that. Unless I’m missing something. If it flops around while you’re playing that’s one thing. Maybe your tech forgot to install the tubing, or maybe the wood in the neck rout is stripped. But if you’re worried that the pickup moves back and forth a little bit when you apply a little pressure with your finger? Sleep well, my friend.
  4. Ira7
    Ira7 Doctor of Teleocity
    Coral Springs, FL
    Like 8barlouie above says, it's okay if you can move it with your fingers, but it shouldn't move by just shaking the guitar.
    Mounting the neck pickup...whether it's mounted by hanging from the pickguard or screwed into the body...is real simple stuff. Any idiot can do it, and if your guy successfully changed the pickup and it's not moving just by shaking the guitar, don't worry about it.
    Crobbins and RoCkstAr256 like this.
  5. RoCkstAr256
    Poland
    I made a video of it, it looks like this . Fine or not ?
  6. parademe
    parademe Tele-Meister
    Berlin, Germany
    Totally fine. If it bothers you though, put a piece of foam underneath the pickup, as already suggested. Should stabilize it a good bit.
    Nice set of pickups btw.
  7. RoCkstAr256
    Poland
    Thanks mate, if its okay its okay i might put a foam later . These new Texas Special pickups shreds, what a power :)
    Floyd Eye and Crobbins like this.
  8. brogh
    brogh Assistant Admin Staff Member
    italy
    oh no ! your guitar is broken send it over here :);)
    Agreed on a bit of foam, that little movement is something not to worry much about, I've seen this on a ton of telecaster :)
    Play music and have fun !
  9. RoCkstAr256
    Poland
    Thanks :D , also frets were filled down, Action is super low. What a shred guitar.
  10. RoCkstAr256
    Poland
    I think ill put some foam cover from texas Pickups (from the box, just cut it a bit ) :)
  11. Motocaster
    Motocaster TDPRI Member
    That’s exactly what I did.
  12. RoCkstAr256
    Poland
    Or maybe ill just leave it :p
    MickM and Crobbins like this.
  13. sothoth
    sothoth Tele-Holic Double Platinum Supporter
    Kepler-186f
    Superglue!
    ianstrike and Crobbins like this.
  14. RoCkstAr256
    Poland
    Duct tape :)
  15. Tonetele
    South Australia
    I have seen this problem a few times. Easiest remedy ( which I don't love) is get a new pickguard with screw holes for the front pickup. The springs and rubbers will hold it perfectly.
    Aesthetically, and correctness , it's not ideal.; however it is the quickest and easiest fix to that problem ( which is a perfect fit into the wood and no screws either side of the neck pickup).
    I have tried the foam trick but the pressure eventually " sinks" that pickup.
    Sorry Pal.
  16. sothoth
    Kepler-186f
    Crap, that’s better than my suggestion :)
  17. RoCkstAr256
    Poland
    Nah ill leave it, it seems its just how it suppouse to be :) .
  18. RoCkstAr256
    Poland
    Which pickguard would fit? Of coruse i need white one :D
  19. Tonetele
    South Australia
    @RoCkstAr256 any white guard with two holes either side of the front pickup rout. Try WD Music.com
  20. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
